<<  16    17    18    19    20    21    22  >>
Author: Subject: Warner R4 Build Diary
cloudy
posted on 18/12/08 at 07:27 PM Reply With Quote
Chassis is still cooking under some sheet, have managed to get it up to 40 degrees even with the sub zero temps in the garage
I'm really happy with the finish - and it should be really durable if I can get it to dry well in these cold conditions...
My air riveter arrived today - It makes the most satisfying noise in the world! Kerchunk PSSSSHHHHH
Anyone have any recomendations for where to get closed rivets for the floor panel - what size and length should I be after?
James
[Edited on 18/12/08 by cloudy]
www.warnercars.com
tomprescott
posted on 28/12/08 at 06:12 PM Reply With Quote
I think it looks absolutely awesome with the roll bar style, only reservation I would have is that it might end up looking too short and aggressive, if it was mine I would build it long and low, like a cross between a sand rail and one of those american drag racers. But to be honest i think it looks great and it'll probably start to look even better when the frame is full!
cloudy
posted on 2/1/09 at 07:38 PM Reply With Quote
Waiting for bloomin rivets to arrive - I hate this time of year where everywhere is closed!
The floor laid out...
[Edited on 2/1/09 by cloudy]
www.warnercars.com
cloudy
posted on 7/1/09 at 09:06 PM Reply With Quote
More waiting... Have corner pegged the panels ready to draw out the rivet locations and predrill them...
Using my new 8.1mp phone for pics - SE C905, I recommend it highly..
[Edited on 7/1/09 by cloudy]
www.warnercars.com
pocket rocket
posted on 7/1/09 at 09:22 PM Reply With Quote
that is a work of art! amazing work!
can't wait to see it out and about at some show's, its going to pull a big crowd!
cloudy
posted on 11/1/09 at 12:17 AM Reply With Quote
Right, I've spent from sunup to midnight in the garage today - and finally I've made some progress !!
Fitting the floor:
Finally the right way up with some of the wishbones fitted.... (The red glow is a reflection from the heat lamp )
[Edited on 11/1/09 by cloudy]
www.warnercars.com
COREdevelopments
posted on 11/1/09 at 07:57 PM Reply With Quote
finish looks great james! keep it up.
Omni
posted on 11/1/09 at 08:11 PM Reply With Quote
AWESOME as always James
WELL DONE MATE.
O
cloudy
posted on 11/1/09 at 09:20 PM Reply With Quote
Another long day - lots of pics for you!
www.warnercars.com
Omni
posted on 11/1/09 at 09:27 PM Reply With Quote
Blimey! You are soooo nearly done. You gonna make SVA?
O
cloudy
posted on 11/1/09 at 10:00 PM Reply With Quote
Should be able to, long as I keep the pace up...
www.warnercars.com
neilj37
posted on 13/1/09 at 10:48 AM Reply With Quote
Most important question is when can i have one
nitram38
posted on 13/1/09 at 05:38 PM Reply With Quote
Probably when you build one!
COREdevelopments
posted on 13/1/09 at 07:50 PM Reply With Quote
wow your progress is great! its really coming together! cant wait to see it at the shows, stoneleigh maybe?
Rob
carpmart
posted on 13/1/09 at 09:07 PM Reply With Quote
That really is coming together in an impressive way now!
Keep up the good work!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
cloudy
posted on 15/1/09 at 08:14 PM Reply With Quote
I have decided the epoxy 121 is NOT the one to go for, it's marking at the slightest hint of contact with anything - I don't forsee it lasting long on the road
James
www.warnercars.com
nitram38
posted on 15/1/09 at 08:32 PM Reply With Quote
That is why I brushed it on.
I had to remove some to weld a bracket on and it is tough stuff. I had to burn it off to clean the metal enough to weld.
Tough but shows scuffs.
cloudy
posted on 15/1/09 at 08:41 PM Reply With Quote
I've sprayed a textured matt finish Martin, it should hide scuffs fairly well - I dont think its the application method...
Parts that were baked in the oven seem far tougher - so i'm hoping a day in strong sunlight should get the paint temp up enough to harden it further...
James
www.warnercars.com
nitram38
posted on 15/1/09 at 09:00 PM Reply With Quote
It is not the application method I am on about, it is the ability to touch up the paint with a brush without anyone noticing. On a smooth paint job, it will show.
I still like how tough this paint is and after your car has been on the road a while, you will probably like it too.
cloudy
posted on 16/1/09 at 11:57 AM Reply With Quote
Well a screwdriver I baked - I had to use a hammer to knock the paint off - so I'm hoping the chassis will eventually set to the same...
James
www.warnercars.com
COREdevelopments
posted on 16/1/09 at 07:07 PM Reply With Quote
as for your paint issue, if you say you have sprayed a textured finish, you would be able to re-spray any scratches and get a decent blend in as its a matt.
both yours and martins build look awesome.
rob
BATHO
posted on 16/1/09 at 08:59 PM Reply With Quote
car looks great, are you thinking of producing this? I think you should!!!
cloudy
posted on 21/1/09 at 10:12 AM Reply With Quote
There might be plans to do so, depends how SVA + road trials go...
The big day arrived today - I put in my SVA1 form, applied for a date in about 4 weeks, so the heat is on!
James
www.warnercars.com
cloudy
posted on 21/1/09 at 09:49 PM Reply With Quote
Finished making a template fuel tank from steel to send to allyfab, There will be a pair of these giving just over 25 litres in total (5.5gallons) - This should be enough I think
[Edited on 21/1/09 by cloudy]
www.warnercars.com
Valtra
posted on 22/1/09 at 02:07 AM Reply With Quote
Don't know what to say . Just stumbled on this thread and spent a couple of hours skipping though it .
I firmly believe you must be one of the greatest natural talents off all time .
Colin Chapman
John Barnard
Adrian Newey
You
Etc etc
"If it looks like it works and it feels like it works, then it works"
