<<  1    2    3    4    5    6  >>
Author: Subject: The Gecko Project
John Bonnett
posted on 13/1/13 at 01:18 PM Reply With Quote
Great progress Dominic despite the heat, well done. I particularly like the way you are tackling the sheet metal work. It all looks very professional. Didn't you fancy making the wings in aluminium?
Keep up the good work
Best regards
John
TheGecko
posted on 13/1/13 at 01:45 PM Reply With Quote
John,
I keep thinking about it But, given the amount of effort (and money ) now invested in the fibreglass ones, I'll stick with them for now. If the enthusiasm remains after the car is on the road, I might have a try at making a form and knocking up some wings, just for the exercise. Doesn't really need to be that hard, if the form is right.
Best regards,
Dominic
TheGecko
posted on 16/1/13 at 01:09 PM Reply With Quote
Tuesday night was a stab at making the first light box. Not a complete success Mostly the problem was me grabbing some leftovers from the same 1.6mm material used to make the main part. Just too thick for something this fiddly and the design is too fiddly as well Oh well, at least it lets me (re)check clearances and spacing etc. This will get remade in something lighter, either 1.2 or 1.0, next workshop visit.
TheGecko
posted on 28/1/13 at 03:36 AM Reply With Quote
And Mk2 of the light boxes (left & right) in 1mm ali were much easier to make plus, Mk1 gave me some tips on folding sequence, which was a multi-stage affair.
I know it looks like the don't fit - the cross piece had been wedged open a bit to mark, drill and dimple drain holes in the light box area. It'll squash back into shape in the chassis.
A few rivets and they'll be mounted. Need some M4 spacers/standoffs for the lights now, which Mr H is kindly going to machine from some sort of plastic (I think - the rain on the shed roof was literally too loud to hear over at some points )
The east coast of Australia is in disarray at present, with serious fires in the south and heavy rain plus flooding further north where I am. Just got an SMS alert from work to say all of our campuses are closed tomorrow so I've got a day at home unless called in. Given the last minute "Oh shit. We need to bring these systems down RIGHT NOW!" we had last time, a phone call is not impossible
Dominic
TheGecko
posted on 26/3/13 at 02:05 PM Reply With Quote
Some updates that hadn't made it into this build diary yet.
Built radiator mounts to suit the existing pegs on the eBay Civic radiator - generic rubber top hat bush in a short tube. Two at the bottom:
And a removable central one for the top:
End result:
There's also been some more fiddling about with panels, including pinning down the size and location of the side vents:
Some interesting work to come making a template to form nice rounded edges on those vent holes - more pics (and possibly a video) once that happens.
I also did a quick mockup test of one panel in plain paper to resolve a question about what size sheet it needed to be cut from. Unfortunately, leaving a plain paper panel stuck on the car with a bored Mr H leads to unexpected "enhancements"
Last but not least, a variety of small manufactured bits have come back from plating (zinc + gold passivating + de-embrittlement) - must try to get a better photo than this one:
Top and bottom are the rear toe links with their adjustable chassis end mounts posts on the left. They use a LH threaded 5/8" rose joint on the inside end and the OEM Toyota tie rod end on the outside. In the middle are two front tie rod extensions and the steering intermediate shaft - Mitsubishi Lancer column spline to Ford (Ka) UJ through to 17mm hex on modified Gemini (Chevette) rack. Hey, why make it easy on myself
Present goal is to get all the structural and panel work completed and shift the car back to my workshop for plumbing/wiring/trimming sometime in the next 6-8 weeks. Need to extract my digit plus find some way of spending less hours in the office
TheGecko
posted on 7/4/13 at 01:18 PM Reply With Quote
I feel like I'm in the department of dribs-and-drabs at the moment. Lots of little invisible bits of stuff happening and very little to show.
Made up the footwell panels - drivers side needs to be set back a bit to meet the back of the pedal box.
Needs some holes - one for the column and three for the master cylinders - to be finished.
The above leaves out the column support etc all in place...
And today, finished some hidden metal work that will support the ali panel behind the rear guards. Mocked up a bit of that panel in cardboard and had a look -the guard will need a small fillet to meet the curve of the panel.
Did the other side and added in the central lighting/grille panel then stood back for a look. Doesn't look awful
Have also made the retainers for the fuel tanks but nothing to show of them yet - soon.
Dominic
maccmike
posted on 7/4/13 at 01:45 PM Reply With Quote
nice sheet metal work
John Bonnett
posted on 7/4/13 at 02:52 PM Reply With Quote
It doesn't look awful at all Dominic, it looks really nice and very well executed. You have achieved some really tidy bends on the square tube. Wherever you look on your project there are some very nice touches. A great thread and a great read. Thank you.
Regds
John
TheGecko
posted on 8/4/13 at 07:26 AM Reply With Quote
Macmike, thanks - I assume you're referencing the light/grille box? It certainly passes the "looks alright at a glance from a few metres away" test. Up close, there's some rough edges
John, thanks also - I've spent a LOT of time sketching and fiddling with various scale models to find pleasant shapes from simple elements. I.e. there's no double curvature panels on the car (other than the fibreglass guards) but I think it all works pretty well. Somewhere I've got a sketch of how the various single curvature pieces intersect at the back - it's harder to draw than it is to build It's a little influenced by Ford's "New Edge" design language, which used the intersection lines between curves to form styling highlights.
The bends in the square tube were all made with a borrowed (cheap Chinese) bender and are in 3/4" (19mm) tube rather than 25mm to ease the process. Hilariously, at the time I made the bends, I was still sketching the final rear end layout so the bends were just short pieces with a (roughly) 90 degree corner and short straight tails. The "proper" way which would have been to bend them to length as continuous pieces. I did at least get lots of practice butt welding bits of 3/4"-18g tube together
If I ever built another (Hah!) I'd know so many better ways of doing things Oh well, Per ardua ad astra and all that.
Dominic
TheGecko
posted on 28/4/13 at 12:05 PM Reply With Quote
Stuffing around with the footwell panel ended with me making it again. It needed a 3mm step in it because, for reasons known only to Willwood, their clutch pedal assembly is 1/8" longer than the brake one
Anyway, here's the end result, along with the floor panel to get ones feet up to the same level as the pedals. Just need a trio of 1-3/8" holes for the master cylinders and one for the steering intermediate shaft and it's done.
Might finally get onto something other than footwells in the next session
D
John Bonnett
posted on 28/4/13 at 01:09 PM Reply With Quote
Another example of the care and attention to detail Dominic. The stiffening swages have been beautifully executed. Have you got a beading machine or did you put them in by hand? The fit and the folding is superb. Well done
John
TheGecko
posted on 28/4/13 at 01:55 PM Reply With Quote
John,
The swages were put on with a set of jenny rolls - one of the advantages of the car being in the workshop it currently is. I'm a little annoyed about the beads in the floor panel - they should go down rather than up but I forgot what side of the sheet I was working on That part of the floor will get covered with carpet or something non-slip anyway so it probably doesn't matter a whole lot. Still annoying though
With the completion of these panels I feel like the car is finally starting to come together, which is nice after all this time.......
Next workshop sessions are Wednesday & Thursday nights this week. More updates as they happen.
D
John Bonnett
posted on 28/4/13 at 05:02 PM Reply With Quote
Originally posted by TheGecko
John,
D
Ah, but being that way up, they won't fill up with dirt
TheGecko
posted on 16/5/13 at 02:05 PM Reply With Quote
So, no updates here for a while but still plenty going on.
Bolted on the neat little mount for the High Level Brake Light (manufacture by Mr H)....
Made a tunnel to cover the water pipes etc that will run from the front to the back. Was originally folded up in one piece but I had to split and join it with rivnuts to make it possible to get in or out of the chassis Still a little bit of trimming etc to do on mounting flanges.
Then some careful measuring was done to establish maximum load size in the front luggage area
Based on that, I made a boot floor to keep the carton off the passengers legs:
Can't do the same thing on the drivers side because the column etc is in the way. So made a little version which will serve to hold jack, tools, etc.
There's still a flat panel to come to cover the column area - ran out of time tonight.
All in all, pretty happy with the last week's progress. Still aiming to get all of the panel-type work done over the next 6-8 weeks and get the car back into my workshop for wiring, plumbing, and trimming.
More soon.
D
TheGecko
posted on 24/5/13 at 01:18 AM Reply With Quote
Made the cover panel for the column area - still needs rivnuts etc.
Also realised I hadn't posted these pics. Rear calipers are finalised after I sourced a pair of late-Mk2 MR2 (SW20) rear calipers. These fit over the Corolla 22mm discs, have a handbrake mechanism, and (best of all) bolt straight up to the Corolla upright. No adapters etc required
Although nowhere near as light as the XF Falcon calipers I was looking at using, the ease of mounting sold me on these.
Back to bodywork.... There was an appropriately sized scrap of 1.2mm ali lying there on Wednesday night so I dragged out the partially complete nosecone buck and had a little play....
Trim the sheet (roughly, this is just a trial) and wrap it around the buck with a couple of wood screws into the back to hold it still....
Smash away at the leading edge with the rawhide hammer for a bit and discover pretty quickly that I'd left waaaay too much edge to knock over, particularly in the corners End result was that I had to snip roughly into the corners to untangle the mess and at least let the rest wrap over. So, some lessons learned about sizing etc, which was the point of the exercise after all. If you ignore the chewed up corners, the rest doesn't actually look too bad for what was probably 30 minutes work
Looks both better and worse in the photo than in real life
This weekend will be back on the welder for little bits of bracketry like bottom harness mounts, handbrake lever, fuel filler, and plenty of others I can't recall right now.
It's progress I suppose.....
D
TheGecko
posted on 1/7/13 at 02:51 PM Reply With Quote
Despite the lack of updates I've been slowly getting things done.
Cut-and-shut the Lancer donor filler neck:
Just found I don't have a decent photo of the engine bay side of that but there's a full metal cover over the pipe so it's not "in" the engine bay.
Have spent an inordinate amount of time faffing around with the grille that will fill the space between the rear lights. First I cut and spaced five ali-strips (temporary bolts obviously):
Then, with some posts to mount the lights on, I could trim some ali angle down like so:
and end up with this result:
All of this will, of course, be painted black when it's finished. Need to make some more bits for the outer corners plus the proper top and bottom mounting tabs for the main grille piece, and it's done.
Have also mounted a handbrake lever and measured up but not yet mounted the gear lever. Just waiting now for the custom cables for both of those (which should be by the end of the week) and there'll be some fitting up and bracket making to do.
D
TheGecko
posted on 2/9/13 at 10:09 AM Reply With Quote
Been too busy with work, home, and organising committee for the Nationals (in pretty much that order) to do much work that actually shows. However, here's a few updates.
Gear shift mechanism has been chopped, flipped, swapped, fiddled, and generally buggerised-around-with until it moves the cables in the right direction for a given stick movement. Temp mount need to be replaced with something more permanent and the relationship between the gear shift cables and the handbrake, with its own set of cables and compensator, needs some addressing
My recommendation for aspiring middy builders - start your design with the gearshift and handbrake and then work outwards from there
Said handbrake compensator, manufactured from raw materials by mine own fair hands
Have also been doing a bit of tin bashing, resulting in the following:
Two updates rolled into one here..... a few days later
Trimmed up the panel a bit more so the gap is virtually nil and clamped up a rear guard for a look:
Offered up the lower rear panel too - still needs to be trimmed and have its edges knocked over for riveting. Looks good already though
Next step is opening up various vent holes and flangeing over the edges - will become more clear once it's done.....
D
[Edited on 2/9/2013 by TheGecko]
TheGecko
posted on 8/9/13 at 09:55 AM Reply With Quote
Another successful few afternoons and evenings in the workshop.
Got the lower rear panel trimmed and knocked over onto its frame
And stuck the under tray portion on to see how it looks
Wrapped a paper template around the side and upper-rear corner (checked the guard and light bar while I was there)
And with the centre part of the grille bars (and backing mesh) loosely in
Drop the template onto the remains of a sheet of 1.2
Yay for air-shears
And spot through the existing rivet holes to locate the sheet in prep ready for rolling the corner, trimming, etc
Ran out of time to roll the corner today - probably Tuesday night's job.
D
posted on 8/9/13 at 10:11 AM Reply With Quote
Smashing work there, some good tips for other builders to follow.
Keep it up
TheGecko
posted on 9/9/13 at 03:21 AM Reply With Quote
Thanks for the support coozer. It makes the sore hands and back feel a bit more worthwhile
D
TheGecko
posted on 10/9/13 at 01:35 PM Reply With Quote
Another fairly successful night bashing tin
Put a 90 degree roll in the panel
Then clamped it in place and marked edges for trimming etc
Did the bottom edge first
No detail photos of the top edge going over (because some of it's not all that pretty yet ) but here's the end result with the lower tail and grille panel in place
Now I need to make another one for the other side and then the little removable "boot lid" panel that goes between them.....
D
TheGecko
posted on 14/9/13 at 09:27 AM Reply With Quote
Not getting much opportunity to work on the car - trade-off with it being in Paul's workshop is that it's a 50km round trip
Still, got the top edges of the side/rear panel tidied up enough to be presentable
Plus, I've been doing some wood-work.....
Which, with a test scrap of ali in it, looks like this...
And makes parts like this..
Some adjustments needed to various dimensions before it's ready for prime time (i.e. to use on an existing panel )
Nothing more until some time next week now.....
John Bonnett
posted on 14/9/13 at 10:11 AM Reply With Quote
Ah, you've discovered the joys of hammerforming Dominic. You're on the slippery slope now. I did warn you that metal shaping can take over your life
The whole project is absolutely magnificent and I really enjoy reading about it and of course looking at the pictures.
I'd appreciate your advice on how best to load pictures up and i'll then update my project.
Best regards
John
TheGecko
posted on 14/9/13 at 10:19 AM Reply With Quote
Thanks John. In some ways I wish I was at the beginning of the project again because there's so much I've learned along the way that I'd like to apply
I'll write you a direct email about how I post images here - hopefully it'll work for you.
D
John Bonnett
posted on 14/9/13 at 12:38 PM Reply With Quote
D
That would be really good Dominic, thank you. I think we have all been in that position where you have learned from your experience and realise that there are sometimes other and possibly better ways to tackle a job or even maybe an improvement in the design. But you have every reason to be really proud of what you have achieved. It is a terrific undertaking to build a car from scratch and the first drive will be absolutely memorable. You'll think, "I made this, and I'm driving it" And then you'll smile
<<  1    2    3    4    5    6  >>
