RWD SHIFTER
svr - 29/5/07 at 09:01 PM
Is it dificult to convert fwd to rwd gearbox - shifter connection?
How do you convert that linkage?
Is there any web site that can help?
Mojo looks too easy but for some reason I belive there is a twist.
StevieB - 29/5/07 at 09:11 PM
The most common route is to use the Ford Type 9 gearbox with a special bellhousing that makes the car RWD - as an example, Caterham use a bellhousing design that enables them to mate the tyoe 9 to the Rover K Series engine (and now the Ford Sigma too).
What engine are you using?
[Edited on 29/5/07 by StevieB]
oadamo - 29/5/07 at 09:19 PM
do you mean rear engined and then run the gear stick to the front
adam
JoelP - 29/5/07 at 09:30 PM
yes, he means how do you connect a gear lever to an engine behind you when it is designed to be in front of you.
iank - 29/5/07 at 09:50 PM
*cough* mid engine forum
iank - 29/5/07 at 09:51 PM
Answer is it depends on the gearbox. If you use a cable change box (like post 94 mondeo's) it's not too bad. A rod selector is more trouble to get right as it usually has to go around or under. IIRC someone mentioned the Corolla shares a gearbox with the MR2 so is easy to adapt.
JC is in the process of engineered something on his blog which will works like the mojo selector. This would be using the ford iB5
Blog here -> http://www.mistrale.blogspot.com/
svr - 29/5/07 at 11:14 PM
I posted in mid engined forum.
Is it possible to use Mondeo post 94 gearbox and zetec z engine or even older CVH engine?
The idea is to use widely avalible stock engine that gives 125+ HP .
Opel or Vauxall 2liter engines produce 150hp - are their gearboxes operating with cables or rods.
Any advice on other models?
And do the car manufactures use cables or rods on some models or some prefer one thing over other?
[Edited on 29/5/07 by svr]
RazMan - 30/5/07 at 08:03 AM
My MTX-75 box just required longer cables but I later changed to a rod linkage running from a Mondeo gearshift to a bell crank on the firewall, then swapping the action (back to front otherwise) using the standard cables running under the gearbox. The result is a nice smooth action with no slack. Rescued attachment Gear linkage.jpg
Syd Bridge - 30/5/07 at 08:51 AM
Morse Controls (Cables) used to do a shifter setup for a couple of production cars. The cables are available in all sorts of strengths, and lengths up to what would go around the car a couple of times.
Syd.
[Edited on 30/5/07 by Syd Bridge]
..::Nightfire::.. - 31/5/07 at 06:40 PM
I have done it with a mini engine. The rod enters the rear of the engine next to the diff.
I rotated the selector,
removed the lift/stop for reverse (as it was now on the wrong side),
fabricated a bracket to the tension bar to keep the gearbox and selector equidistant at all times,
Welded a rod to the collar and ran it under the sump.
The moral of the story is to use a gearbox that uses cables!
kb58 - 31/5/07 at 07:38 PM
I use two push-pull cables for my Honda-powered mid-engine Mini. The cables are from www.push-pull.com
