Apart from R888s and A048rs are there many reasonably priced toyo proxes equivalents for 13" wheels?
Yoko do A539's A021's & A032's but the 539's are road tyres, the 21's are wet/gravel tyres & the 32's are inbetween 48's & 21's AFAIK
One of the best tyres I have tried in recent years has been the Goodyear Eagle F1. This tyre made an unbeliveable differance to the grip, turn in and steering feel on my Pug 306 Gti 6.
Best tyre recently used on a road car have been Bridgestone potenza RE720's, which at £45 a pop fitted an balanced are a flipping bargain (195-65-14's)
Best I've had on a roadcar are toyo t1-r's I've replaced the worn fronts with falken ze502 or 512 (can't remember which) and
they're not as good.
Ned.
I have 32s (precursor to 48s) on my westfield and they're as sticky as a sticky bun dipped in glue... unless it's cold or wet. If it's
really grim I have a set of eagle nct2 which shift standing water better but aren't very sticky at all.
I have t1s on my mk2 golf 16v gti and the turn in is amazing.
When the 32s are dead on the westy I'll try some t1rs as they car is mainly used on the road and I can't justify the cost of the 48s and
they aren't so flexible given that it seems to rain a fair bit when I want to go out.
Depends on what you're used to though.
[Edited on 27/4/06 by dern]
T1-Rs are brilliant, they're on my wife's mx5 and stick wonderfully even in the wet.
THe only problem is toyo don't make them in a 13 and neither do goodyear. The other performance options are just silly money for road tyres,
especially when I can get T1-Rs fitted for £40 a corner (195/50/15) so I've decided to go for 15s for on the road and use my 13s for track days.
I've experienced most of the above tyres and they're all pretty good, probably depends more on cost.
I haven't tried the Dunlop D01js but they seem to be highly regarded and priced to match I believe. I think the DZ02G may be the replacement for
them.
The Faulken ze512s are a good budget (£35 ea fitted) tyre which I originally built my kit car. Designed for light cars with a soft side wall and hence
lots of slidy fun on track. no where near the grip of my curretn R888s.
