Hi All
Can u fit the sierra front callipers upside-down (bleed nipple pointing down) on standard hubs
Kev
Think about trapped air!
That is why they are best at the top........to let the air out
Having a problem flexi pipes torching top wishbone on full lock. This should stop the problem I have tried the usual.
If not I will have to move the position of where they come out the side panels but didn't want to do this
No reason why you cant, but you will need to remove the callipers and turn them the right way up when bleeding the brakes and use a pressure bleeder
This is how they are mounted on the backs of my mk. not a problem really like 'pbs' says.
