The clearout countinues...
MIG Welder R-Tech I-MIG160
The I-MIG160 MIG Welder is a 160 Amp Industrial Quality Inverter MIG Welder with a 240v single phase input, MMA (Stick) Facility and Spool-on-Gun
Attachment option for aluminium welding with 1kg rolls
* Provides very smooth welds on all steels and aluminium due to its inverter technology
* 160 Amp Output, welding range 30-160 amps
* 240V 13A input required - works from a standard plug
* Generator Friendly - Generator must be minimum of 4.8KVA and fitted with AVR (auto voltage regulation)
* High duty cycle - 60% @ 115 amps, 35% @ 160 amps
* Infinite control of welding voltage/amperage
* Adjustable Arc Force - Soft/Harsh Weld - Controls Splatter
* L.E.D Amperage & Voltage Display
* Takes 5KG 0.6 wire or 0.8mm wire
* Package Includes, R-Tech I-MIG160 MIG Welder, 3M MB15 Air Cooled MIG Torch, Earth Lead, Gas Hose, Mains Cable, Gas Regulator, Owners Manual
Never used, comes with a reel of 0.6mm wire
£400 ono
Starparts Light Reactive Welding Helmet Silver
The starparts BETA-S is a high specification welding helmet with many features including twin optical sensors, shade control 9-13, low battery warning
light and a striking paint design. Made for the discerning welder.
* Latest Modern Lightweight Design Welding helmet
* Silver Artwork Design Welding Mask
* Variable Shade Control - Din # 9-13
* Two Optical Sensors
* Reaction Time 1 - 20,000 Seconds
* Adjustable Hi-Low Sensitivity
* Adjustable Delay
* Low Battery Warning Light
BNIB £80 ono
Sealey SC10 1 Ton 1T Folding Engine Crane
Used no more than 10 times, Excellent condition
£130 ono
Sealey Engine Stand
Used once, £20
[Edited on 1/2/12 by hicost blade]
Where about in Oxfordshire are you?
As above.
Am interested in the engine stand
Bump
As asked, where are you in Oxfordshire? I could do with another engine stand.
Chris
Chris
