garage clearout.
Schrodinger - 18/7/16 at 08:14 PM
having just bought a part built Stylus I may as well get rid of the bits I have accumulated for building an Avon.
3.91 7.5" Diff £50
diff
diff
diff
diff
bolt on drive shafts with disk hubs £50
drive shafts
drive shafts
Avon front wishbones £75
wishbones
wishbones
throttle body adapter from a ginnetta to use ford tb and idle control valve £15
Throttle body
Throttle body
cortina uprights £75
cortina uprights
cortina uprights
cortina calipers £10
old callipers
old callipers
escort? calipers £30
callipers
callipers
escort uprights £75
uprights
uprights
escort hubs £20 pair (2 pairs)
all of these are in Aviemore, I would prefer that they are collected as they are all heavy.
[Edited on 18/7/16 by Schrodinger]
tims31 - 19/7/16 at 02:34 AM
Interested in the throttle body adapter, any chance you could post on?
U2u me with postage details if you can please.
Schrodinger - 19/7/16 at 09:51 AM
Will get the costs and let you know.
Schrodinger - 20/7/16 at 01:09 PM
bump
Schrodinger - 21/7/16 at 07:47 AM
you have u2u
the_big_1 - 21/7/16 at 06:27 PM
Hi,
Very interexted in the wish bones if you still have them?
Schrodinger - 21/7/16 at 09:21 PM
Yes the wishbones are still available.
I will get a price for posting if you are not likely to pick them up.
the_big_1 - 21/7/16 at 09:34 PM
Sure yes please.
Could you PM me so I get dimentions off you to check they will fit my build etc.
Many thanks!
Schrodinger - 21/7/16 at 09:55 PM
I will try and get them tomorrow, they are Tiger supplied wishbones so they should fit.
the_big_1 - 24/7/16 at 06:19 PM
Hi ya,
Did you get my PM?
Cheers!
Schrodinger - 24/7/16 at 07:31 PM
Yes I have,
are these pics any use?
the_big_1 - 24/7/16 at 07:51 PM
Damn!!! 10mm shorter across the bushes! :-(
Schrodinger - 15/8/16 at 11:48 AM
bump
the_big_1 - 15/8/16 at 12:04 PM
Hi,
Do you know the bolt pattern for the bolt on drive shafts?
So I can check if they will fit my new diff.
Cheers!
ash_hammond - 15/8/16 at 12:04 PM
Interested in the shafts. Are they Sierra LSD type?
the_big_1 - 15/8/16 at 12:23 PM
Me first lol
ash_hammond - 15/8/16 at 12:49 PM
Originally posted by the_big_1
Me first lol
Yes in deed you get first dibs. I would be interested to see how many seconds you got there first by as both ours posts were 12.04. :-)
Schrodinger - 15/8/16 at 04:59 PM
The shafts bolt on to the diff that's also for sale I was not aware that there was more than one bolt on type but I will try and measure the bolt pattern for you. I will also have to weigh the shafts to see how much postage is.
the_big_1 - 15/8/16 at 09:20 PM
Hi,
If you could that woud be great!
I have the diff being shipped from Cornwall for £13, check out
https://www.parcelmonkey.co.uk/
misty1 - 16/8/16 at 01:09 PM
also interested in the shafts
Schrodinger - 16/8/16 at 01:36 PM
I have just measured the shafts they have a pcd 86mm x 6 m8 bolts.
with the hubs these weigh in at 25kg.
I live in Aviemore which means I have to pay the Highlands & Islands premium but I will shop around and see what I can do for postage. I may work out cheaper to do it as two packages.
Got some quotes cheapest £15.83.
let me know if this is ok.
[Edited on 16/8/16 by Schrodinger]
the_big_1 - 16/8/16 at 04:52 PM
Hi ya,
Yeah prices are fine.
How do you measure the PCD? Just so I can ensure I am correct.
Are the lengths of shafts:
28 splines inner & outer, length 50.4cm. 7.5″
28 splines inner & outer, length 46.4cm. 7.5″
Many Thanks,
Carl
Schrodinger - 16/8/16 at 07:03 PM
These are bolt on shafts so there are only splines on the outer end, will need to check number.
mcerd1 - 16/8/16 at 07:43 PM
ignore the 'x' dimension
I think he may be talking about the splines that are inside the boots - what the CV's are mounted on...
[Edited on 16/8/2016 by mcerd1]
the_big_1 - 16/8/16 at 07:52 PM
Cheers guys,
Do you know if there is only the one type of 7.5" shafts in the above lengths, its all I can find.
If so, they are mine lol
the_big_1 - 16/8/16 at 09:35 PM
Hi ya,
Best measurement would be from where the shaft connects to diff and to hub face where disc would mount.
That would be ace if you could.
Also, how would you like paying etc?
Schrodinger - 17/8/16 at 09:51 PM
I'm away atm for a couple of days but should be able to measure up on Friday.
the_big_1 - 17/8/16 at 09:59 PM
Hi ya,
Sure, no problem at all!
Schrodinger - 18/8/16 at 09:55 AM
3.91 7.5" Diff £50
diff
diff
diff
diff
drive shafts
drive shafts
Avon front wishbones £75 SOLD
throttle body adapter from a ginnetta to use ford tb and idle control valve £15 SOLD
cortina uprights
cortina uprights
cortina calipers £10 SOLD
callipers
callipers
escort uprights £75
uprights
uprights
Schrodinger - 21/8/16 at 10:10 AM
I have just measured the shafts and they are 61cm and 58cm long.
the_big_1 - 21/8/16 at 01:50 PM
Hi Keith,
I take it that was from bolting face that attaches to diff to hub fave where disc mounts?
If so, let me know how to pay you etc as they would fit perfect!
Schrodinger - 21/8/16 at 02:31 PM
yes that's the measurement
I've sent a u2u.
Schrodinger - 21/8/16 at 03:25 PM
drive shafts now sold
Alexd186 - 28/8/16 at 08:16 AM
Hi just wanted to say received the calipers etc, well packaged. Great work, thanks
