Does anyone know where to get one. I have both a mechanical and a GPS speedo sender unit and I'm looking for a switch that I can connect both
sender wires to with one output to the speedo so I can just toggle between the two. Struggling to find one even though it's something I thought
would be easily got, just something to toggle 2 inputs to one output.
you just need double pole double throw switch so as one set of wires connects the other set is disconnected. it'll have 6 contacts on the back
DPST...double pole single throw......DPDT double pole double throw
DPST has 6 terminals DPDT has 8........
Hi
Not good with electrics, but would an indicator switch do the job
dash mounted one or toggle switch on-off-on ?
Car builders have them.
Good luck
Or a single on/off switch to a 5 pin switching relay.
Sounds like you are all making it very complicated.
Assuming they are both digital outputs the you just need a Single pole double throw switch like this
http://www.maplin.co.uk/p/ultra-miniature-toggle-switch-spdt-fh98g
Connect the center pin to the dash and the other two pins to the signal wires
Thanks guys, that SPTD switch is what I need, I knew they should be easy enough to find but I simply could not find what I was after.
they also do a push button
http://www.maplin.co.uk/search?text=push+button+spdt&x=-466&y=-46
a dpdt switch has six terminals,
a dpdt relay would have 8
http://en.wikipedia.org/wiki/Switch
i dont want to be a pedant about this but most of my 6 terminal switches are a single action to change states, as are some of my 8 pin switches (haz switches are a good example which are also single pole.....) but most of the switches i have which have a double action (off,on,on OR on,off,on) have 8 or more pins. that are also double throw single pole switches which have 4 pins......but the term double pole double throw (DPDT) indicates a switch that has two additional switch-able positions from "rest", with two poles
