Thread Identification - Help!
TimC - 28/11/06 at 03:55 PM
Hi All
Have a problem,,, I can't identify the thread on a fitting I have. It's from my pre-drilled oil cooler bolt on my R1.
Its the one on the right hand side of the following pic:
Warning - quite large!
The thread on the left is M10x1, the middle is M10x1.25. The one of the right sort of looks like M10x1 but I'm not convinced. What do you think?
It's not UNF/UNC/BSW/BSF. Help appreciated!
[Edited on 28/11/06 by TimC]
Alan B - 28/11/06 at 04:04 PM
Either 1/8 NPT or 1/8 BSPT.....you can see the taper on the pic..unless it's my eyes...
1/8 NPT is 27 TPI so it will look close to M10x1.0
tasmin289 - 28/11/06 at 04:09 PM
1/8 BSP?
or 1/8 NPT?
RazMan - 28/11/06 at 04:14 PM
It is a fair bet that it is npt as a lot of sensors use this thread
Hellfire - 28/11/06 at 04:17 PM
Agreed. I'd go with 1/8th NPT.
Phil
TimC - 28/11/06 at 04:18 PM
Just got the verniers out - doesn't taper.
Alan B - 28/11/06 at 04:22 PM
You certain?....it sure looks tapered..
Another option would be 1/8 BSPP, but there does not appear to be a proper shoulder for a sealing washer......
chockymonster - 28/11/06 at 04:24 PM
My Oil pressure one didn't taper either but the hole it went into did.
The problem was it wouldn't seal properly on the oil cooler bolt as it was too short.
So I remote mounted it with bits bought from thinkauto.
TimC - 28/11/06 at 04:27 PM
Double checked - no taper. It has a larger 'shoulder' and I think this combines with the change in colour to trick the eyes!
indykid - 28/11/06 at 06:13 PM
well measuring off my screen, with a steel rule, it does have a taper. about 63mm at the bottom of the thread, down to about 57 about 3 threads down from the end. that's 35mm of thread length for scale.
the other 2 measure up as parallel though
could that be npt then?
tom
MikeRJ - 28/11/06 at 06:46 PM
I've not ever seen an oil pressure switch (or is it a pressure sensor?) that didn't have a tapered thread. Presumably it will have to be sealed with a copper washer if it has parallel threads?
TimC - 28/11/06 at 06:55 PM
You're right - the very end tapers - I though it needed to be further up - what do I know?!
BenB - 28/11/06 at 07:16 PM
Indykid- your ever noticed your avatar looks very like a Locost coming out of the Bunker in Return of the Jedi just before the Ewoks turn up?!? Just need a couple of Stormtroopers and you'ld be there Maybe I've had too much coffee today.....
t.j. - 28/11/06 at 07:35 PM
what is that coin???
Still no Euro.....
You lucky b*st*rds
We are now after 5 years climbing out of the euro-bad weather
theconrodkid - 28/11/06 at 07:41 PM
thats 2 pence,100 pence in £1,cant buy anything for less than £1 here
DIY Si - 28/11/06 at 07:48 PM
Even penny sweets aren't anymore. Well, not the real ones from when I was a kid!
spunky - 28/11/06 at 08:41 PM
guessing it's the same as fitted on my SP1 engine, (looks the same) So 1/8 BSP.
Had same issue identifying the thread, pretty surprised to find the Japs using BSP.
John
TimC - 29/11/06 at 09:21 AM
It wasn't sarcasm. I meant it - what do I know?
No worries - help very much appreciated fella.
foes - 2/12/06 at 09:22 AM
John
it'll be 1/8 bspt (tapered) not bsp (parrallel). Most jap car engines (so i presume bike engines also) use bspt for oil pressure senders etc, and aftermarket jap gauges eg hks, apexi etc come with bspt fittings.
carl
