Hey Guys,
Maybe dreaming again, wondering if I could change my beetles old wheezy 1.2ltr that generates an awesome 24hp! With a mini engine sacrilege I’m
sure but sod it…
One small point or hopefully so is just low long is a mini engine, anyone know? Haven't got a lot of room in the back of the bug
Oh and what is the largest standard capacity that the engine comes in and the kind of death wish power I could expect from such a monster!
cheers
[Edited on 22/9/08 by Mr Whippy]
http://www.vanbran.com/bug/conversion_main.htm
I've always had the utmost respect for your opinions, and you go and ruin it all in one post
Stick a 2.2 camper engine in, or a scooby engine, or mid mount something!
*cough* bike engine
gsxr 750 would be perfect, they are tiny.
Or, if you can find an adaptor plate as they have stopped making them, fit a flat 4 out of an Alfa 33 = 120bhp. Fit two mini rads either side of the
drive shafts for cooling. Don't forget you will lose the warm air heater so will need to organise a heater of some kind . Also strap down the
gearbox as the standard gearbox mounts will not withstand the extra torque.
[Edited on 22/9/08 by jabs]
As above...scooby or porsche engine..... Dont fanny around with a mini ....
hmm cheers but well I have like drums all round...a mini engine sounds safer
oh I've had bugs for almost 19 years now, could easily make a track car if I wanted but this isn't going to be one. Engines to loud and slow for this car and I want a small water cooled lump instead so I can hear my stereo and have a good heater. Don't want to change the shape of the back and want to keep it light there too seeing that its the swing axle suspension. The flat four Alpha's are becoming too rare now, mini engines are dead easy to get hold of, just wondering if one would fit?
my mini 998cc A series is 18inches (470mm) from the tip of the water pump pulley to the endplate where the clutch casting bolts on.
scooby gets my vote
The older scooby EA81 flat four 1.8L is possibly your best bet...
Was in the MV pickup....
Really simple, and bulletproof...they use it in homebuilt aircraft in the states!
as a scooby owner for the past 5 1/2 years, i would say a scooby engine, the most popular for these seems to be a 2.2 from a Legacy.
But its not what he is after here.
would a larger capacity beetle engine not be the best to do?
BMW K100 engine?
If you're looking for a bit of inspiration check out the Z-Cars website. These guys are putting Honda V-TECs and bike engines in the back of Minis. Makes you realise what's posisble in the back of an old car.
I'd have to say this has a certain appeal
a spooky quiet bug!
Electric......how far are you planning on going in it?
Even the 1600 beetle engines are... lacklustre, topping out at 50bhp, though if no brake mods are planned that would probably be plenty
water cooled camper engines in them can give some proper performance, but the biggest arse with watercooling a beetle is putting the rad somewhere - it usually looks utter cack.
well the bug engines have that huge great fan spinning round all the time at about twice engine speed, god knows how much power that saps!
a common conversion is the rotary engine, small, light and 300 hp N/A or 500 + blown................ You can even buy the bellhousing conversion plate. There is a guy on Mazdarotaryclub who has an N/A one. Runs a 14 sec 1/4 IIRC
going on the amount of air it puts out I don't imagine it would be very much - 1/4 to 1/2 HP at the most?
normal range seems to be about 40miles with batterys depending on how many are fitted kind of limiting I supose, would be fun though
try holding something need the fan air intake at full throttle! ran the buggys one without the body on, quite an air flow through it
BMW K100 engine?
