New Topic New Reply
Author: Subject: MK Pinto Engine Mounts
James
posted on 9/1/03 at 01:38 AM Reply With Quote
Just a quickie please!
Those of you that have bought MK's Pinto mounts (the type that use the Fiesta gearbox mount), are they the same length each side or is the left longer than the right?
If they're the same, I take it the chassis mount point is (approx) 30mm inboard on the left side relative the the right hand one?
Thanks,
James
bob
posted on 9/1/03 at 05:35 AM Reply With Quote
JAMES
Same length mate.
But end plate that bolts to eng is set at an angle,not sure about mount plate position far too cold out there to check right now
auzziejim
posted on 9/1/03 at 07:26 AM Reply With Quote
are the MK pinto mounts suitable for the sierra 1.6?
James
posted on 9/1/03 at 10:14 AM Reply With Quote
Thanks Bob.
James
mac#1
posted on 9/1/03 at 08:44 PM Reply With Quote
MK Mounts
Quote "Same length mate."
Er.. not quite correct Bob, suggest you check them out!
bob
posted on 9/1/03 at 09:49 PM Reply With Quote
Yep they are a bit different,i braved the cold for that.
James
posted on 10/1/03 at 11:43 AM Reply With Quote
Blimey! Listen, cutting 50x50x3mm box by hand isn't easy ok- sort your facts out!
Only joking Bob, thanks for that. I hope you're monkeys aren't too brassed as a result!
I've resorted to two oil filled radiators in my garage. They get turned on when I get home from work and by the time I'm changed and have eaten the air temp is slightly above freezing.
Thanks,
James
bob
posted on 10/1/03 at 07:34 PM Reply With Quote
JAMES
Really sorry about this mate,but i had to measure it properly and guess what !!!!.
Both the same length,its one of those optical illusions or whatever.
Drivers side is set at a steeper angle so it looks shorter,i know someone who builds indy's profesionally so i'll ask him for you.
bob
posted on 10/1/03 at 10:31 PM Reply With Quote
but hang on a minute
I've just finished reading the section on mounts in the avon book,they are unequel lengths for the pinto in there
So back in the garage and measure up again,getting bored with this now.
Still the same from the top,but drivers side is steeper set and if there is a difference its not much.
[Edited on 10/1/03 by bob]
auzziejim
posted on 10/1/03 at 11:07 PM Reply With Quote
bob you seem to be that man to ask here are all Pinto mounts the same? or will i need different mounts for a 1.6l to your 2.0l?
bob
posted on 10/1/03 at 11:19 PM Reply With Quote
I think they are all the same but i'm sure one of the pro mechanics will put me right.
I am actually a bit confused with the mounts bit as nearly everyone i've spoke to have unequal lengths,mine are just different angles.
Still the eng and box are in and all seems well so who cares.
speedthing
posted on 11/1/03 at 12:04 AM Reply With Quote
they do differ in angle if you look at the
webbing on the pinto block it sticks out further on one side
redeye
posted on 11/1/03 at 10:43 AM Reply With Quote
r u going to put up some pics of the car with the engine and gearbox in bob?
bob
posted on 11/1/03 at 11:48 AM Reply With Quote
As soon as i can blag another digi cam i'll put a couple on
bob
posted on 11/1/03 at 01:07 PM Reply With Quote
Right sorted it,although if i'd looked more carefully in the 1st place blah blah blah.
Mounts for pinto are the same length RHS each side,they are though set in a different position on plate that bolts to rubber mount each side.Thus making it a longer reach on one side.
James
hope this sorts it out for you
[Edited on 11/1/03 by bob]
mac#1
posted on 11/1/03 at 04:39 PM Reply With Quote
bob there should be 30mm difference between the two.
mac#1
posted on 11/1/03 at 04:42 PM Reply With Quote
engine mounts
all sohc pinto mounts ie 1300/1600/1800/2000cc are the same.
bob
posted on 11/1/03 at 07:16 PM Reply With Quote
Yep 4sure there is 30mm diff,but not in arm length.Mine are set 30mm further over on base plate,but maybe thats just mine.
I bet there are loads of different variations,suppose at the end of the day as long as it works.
donut
posted on 14/1/03 at 07:15 AM Reply With Quote
Bob
Would the fact that your mounts seem to be different be anything to do with your engine coming from a Transit?
Just a thought (very unusual for me!)
bob
posted on 14/1/03 at 03:08 PM Reply With Quote
No andy tranny block is the same as car,the reason is time and ease of fabrication.its a lot easier and quicker to chop a load of steel the same size,and then have a jig for left and right IMO.
New Topic New Reply
