Chassis completed
speedyxjs - 13/5/08 at 07:38 PM
Completed my chassis ready to paint tomorrow.
Hopfully the Jag lump will be more powerful than what i currently have in the engine bay
Chassis Rear
Chassis Rear
Chassis front
Chassis front
1 DP Motor (Dog Power)
And finally the IRS made up from cut and shut A frame from donor car
IRS
IRS
Mole - 13/5/08 at 07:44 PM
Very nice I assume with the width of the tunnel its a wider chassis or do you just have tiny feet
ReMan - 13/5/08 at 07:45 PM
Nice, But aren't you gonna weld the suspension brackets on before you paint it?
speedyxjs - 13/5/08 at 07:52 PM
Its the same width as the haynes roadster chassis but the tunnel is wider. I drove a formula silverstone last weekend which has the same amount of room in the footwell and i coped alright
I havent been able to make them jet (see other post) so i thought it would be easier to paint the middle and back on my day off in the sunshine and just paint the front when i have got the brackets.
clockwork - 13/5/08 at 08:36 PM
Nearly at that stage myself, but bearing in mind your choice of engine, do you think you may need a bit more bracing than TR1 can provide? Now I have no knowledge of beam theory (bought a good book, but almost died when I tried to read it)... but if you have a look at this thread
http://www.locostusa.com/forums/viewtopic.php?t=3478
scroll down to seven sw... what do you think to their replacement. Might be something to think about.
BenB - 13/5/08 at 09:27 PM
We need a new forum!!
DEC
Dog enginned car...
Whats the conversion factor from dog power to horse power....
And we better not talk about reving the nuts of the engine
bpgoa - 14/5/08 at 10:01 PM
don't want to pee on your bonfire... but there's a bit to go before it's finished... add all the brackets before you paint ...
nose cone mounts , centre prop bearing, tsteering column mounts and on and on and on...
I've read the horror stories re grinding off the powder coat...
looks good though...
A..
omega 24 v6 - 14/5/08 at 10:18 PM
Hey clockwork your sig with the car builders info took me to a site where one of these virus scan type things starts up. AVG picked it up as a trojan downloader. ?????? it was on the interiors part of the site.
iank - 14/5/08 at 11:51 PM
Fixed the problem, I hope.
%^&%*%^& wiki vandals.
omega 24 v6 - 15/5/08 at 09:05 PM
Seems OK now. Must remember not to click on victorias secret ever again
