Reverse box stopped working
mr T - 4/9/13 at 10:30 PM
So tonight it stopped working it would go in reverse but wouldn't go back into drive so I've got it out and stripped it apart there wasn't a lot of oil in it and small specks of metal that were stoping the drive cog from re engaging
Can anyone tell me the best way to clean it out and what is the best oil to put in and how full do I fill it
Cheers tony
P.s it's a mnr box
big_l - 4/9/13 at 10:37 PM
Your not having much luck !
Probably best to phone MNR in the morning I'm sure they won't mind chatting to you about the process !
mr T - 4/9/13 at 10:38 PM
Haha
No your ok
steve m - 5/9/13 at 06:23 AM
I thought MNR only supplied top notch goods
mark chandler - 5/9/13 at 10:48 AM
As you are reluctant to talk to the supplier, with hardly any oil I suspect their interest will be low any away.
If mine I would remove, flush through with paraffin or diesel and shake all the bits out, then examine for damage.
If the bearings are rough or damaged then look at them, there will be a unique part number so order and replace, a couple of little chips on gear teeth you will just have to live with.
Maybe even drill and install a magnetic sump bung to trap grinding s in the future if this does not exit today.
Regards Mark
mr T - 5/9/13 at 04:04 PM
Thanks Mark
Box is now back together and working just need to put it all back together
What I did find was that the output shaft on the engine is turning when the engine is is in nutral so when you try to engage reverse the cog on the reverse box is turning on the engine side and the cog to the rear of the box is still causing it to grind when you engage
Looks like the only way round it is to stop the engine before engaging reverse
Cheers tony
Just found that if I push the clutch down in neutral the engine shaft stops turning I've been putting it in reverse in neutral and that's why it's been grinding the cogs
Also when it's in first gear with the clutch down the output shaft is turning very slowly, so it's nutral with clutch down to change into reverse
[Edited on 5/9/13 by mr T]
yahshuatwo - 6/9/13 at 05:29 PM
better come try the r-falcon FNR from the USA
mr T - 6/9/13 at 05:43 PM
Ok nice one send us one ill give it a go
Ian Jones - 6/9/13 at 09:17 PM
ill try one as well please :-)
Fencewrecker - 1/10/13 at 06:41 PM
Hi Mr T
I am aware that it uses a special oil specific to the bearings used. The engineer in me knows from experience the expensive consequences of using the wrong oil.
Also did you go to Donnington this year.
Good luck with the reverse box.
Dave
mr T - 6/10/13 at 11:16 AM
Originally posted by Fencewrecker
Hi Mr T
Dave
Thanks for that wrecker do you think the chip fat I put in will be ok then
Fencewrecker - 6/10/13 at 07:15 PM
Hi
Only if you have put it through a sieve first, changed its chemical signature and not over filled the box. On the bright side you can use the chip newspaper to carry the bits hope after the box explodes.
Happy days.
some people are beyond hope!!
