Carb breathers
greavesy7 - 8/3/15 at 09:53 PM
Is it important to have pipes onto the carb breathers then fed to the front of the car or can you just connect them up to a small filter ?
[Edited on 8/3/15 by greavesy7]
CosKev3 - 8/3/15 at 09:59 PM
Pretty sure most just leave them vent to atmosphere from what I've seen.
Could pipe them into air filter base I suppose if you don't want them open
greavesy7 - 8/3/15 at 10:01 PM
Does it actually do anything ?
cosmick - 9/3/15 at 08:05 AM
Carb breathers go to the float chamber which MUST be at atmospheric pressure. Do not face them forwards into the air stream. Do not join them together as I have seen. Put them in a place where they will breath still air.
jacko - 9/3/15 at 04:35 PM
Engine
Engine
Not a bike engine but zx9r carbs you can see the filter on the carbs the pipe is standard too zx9r carbs
Jacko
FASTdan - 9/3/15 at 07:20 PM
Joining them together is fine - most come like that as standard!
cosmick - 9/3/15 at 07:46 PM
I think there is a misunderstanding with regard to my post. Do not join together means that both sets of float chambers need to breath to atmosphere. Provided that is via a T piece, they can be joined together as long as they can still breath. I have seen people join the two pipes together so that neither float can breath. Hope this helps.
[Edited on 9/3/15 by cosmick]
kj - 9/3/15 at 08:21 PM
Mine open into the atmosphere no filter
FASTdan - 9/3/15 at 10:25 PM
ah ok, yes agreed
