Blade engine query
Squadge - 28/7/16 at 07:41 PM
Hi everyone, can you run any of the blade engines with a wet sump and a baffle or do they need a dry sump kit?
Marc
gaz_gaz - 28/7/16 at 07:51 PM
wet sump is fine. Ideally a billet sump with baffle plate from AB Performance.
Squadge - 29/7/16 at 03:48 PM
Ace,does that go for all blade engines?
sam919 - 29/7/16 at 09:14 PM
Pretty much, i've ran a 919 and currently a 998 and they've both had the AB sumps and if memory serves.....shortened strainers. Both in race situations.
Matt21 - 31/7/16 at 10:45 AM
Standard sump is fine
I have had mine 4 years now and had no problems with oil (unless you do something silly like not tighten the sump plug or knock it loose on a large speed bump).
My oil pressure stays steady on long fast corners, accelerating and braking.
I'm after a billet sump now purely to solve my ground clearance issues, though it isn't essential as long as you know the sump is low (on my car anyway)
Squadge - 31/7/16 at 06:47 PM
cool, thanks for the advice people
