Hayabusa coolant
Hutch - 16/5/18 at 02:03 PM
Hi
I have a westfield xtr2 with a 1400cc busa engine fitted,
I took the car out to snetterton last week and it started to get hotter than normal.
Itís only running a standard polo radiator with water/antifreeze in it. Iíve ordered a new alloy radiator along with some new pipe work and hoses.
What coolant are people using?
Bigboystoys - 16/5/18 at 06:10 PM
Just a good coolant for aluminium engines is fine just change it every couple of years if used on road and a bit more often if tracked.
Just check water is circulating ok, is it running electric water pump or standard Busa one?
[Edited on 16/5/18 by Bigboystoys]
Jon Ison - 16/5/18 at 06:33 PM
How hot is hotter than normal?
Normal = when your driving on the road or previous track work?
Hutch - 16/5/18 at 07:35 PM
Iíve only done a couple of Trackdays in this car and this is the first one this year, it normally sits around 90 - 95 but it was creeping up above the100 mark, I was then backing off and allowing to cool,
Iíve purchased the ally radiator as I donít think itíll do any harm and just wanted to make sure I was putting some descent fluids in.
@Bigboystoys yes it is running an electric pump
Bigboystoys - 16/5/18 at 07:40 PM
Check the pump is circulating if it's running a pressure cap on rad check it or for the cost change it, I wouldn't worry too much my radical used to sit about 95/100 after a hard session on track. From memory the fan when in bike doesn't cut in till about 105 c
