'08 R1 - No Fuel Pump prime or Crank
woodsy144 - 13/6/23 at 12:02 AM
Hello all,
I have put an '08 R1 engine and loom in the back of a car.
Its all wired up but I am experiencing a small issue.
Basically, when I go to on and then crank, there is no fuel pump prime or crank. I find this odd cause I am getting
- all lights on dash working with no codes
- bike in neutral
- ex-up valuve does it check
- throttle system primes and does it check
- kick stand is up
I have checked the voltages and fuses around the starter relay and that all appears good.
Is there something I have missed that is causing the pump not to prime and allow to start. Any help would be great.
roadrunner - 13/6/23 at 06:01 AM
Does it have a tilt switch.
woodsy144 - 13/6/23 at 06:02 AM
Yes it does, and that is positioned correctly, with the word UP, facing up.
roadrunner - 13/6/23 at 06:13 AM
What ignition are you using.
Is it the bike ignition.
Does it have an Immobilizer.
Mr Whippy - 13/6/23 at 06:14 AM
have you check the tilt switch is actually working? Do you have a meter to check it or to check if there's power to the pump? Usually these kinds of things are something daft like a blow fuse, missing or bad earth, loose connection, faulty relay etc...
woodsy144 - 13/6/23 at 06:36 AM
It does, but that has been bypassed and proved out (on initial vehicle install). Nothing has changed in that circuits so I dont think it is that
As for the tilt switch, I confirmed it was all working.
I have checked power to the pump and it appears it is not getting power. I have checked and it is earthed correctly.
Which is making me further think it is a logic thing - or as you say a stupid earth issue.
Only other thing I can think is the black relay box that has the large connector. Is there anyway to check functionality?
adithorp - 13/6/23 at 10:38 AM
So on the top surface, not on the side with the writing the right way up (common mistake).
Is the kill switch on or bypassed? That stops crank and fuel pump.
[Edited on 13-6-2023 by adithorp]
Mr Whippy - 13/6/23 at 11:42 AM
start with the obvious and simple and test with a meter rather than assume things are functioning like the kill switch.
TimC - 13/6/23 at 04:15 PM
If I get chance tonight, I'll check my diagrams.
adithorp - 19/6/23 at 07:24 PM
Did you get anywhere with this?
