scratch build exoskeleton thread
drt - 8/12/13 at 02:00 PM
Hi,
Yesterday I was over the moon I could finally verify an email adress with LCB,
been reading for years As from now I can join .
I'll keep it short,
The car is of exoskeleton design and exist complete in cad.
Everything has been calculated and recalculated.
The problem I have... is that since I began building the frame months ago
the car reached MK999 because I can't settle on an engine/drivetrain
And keep redesigning everything everytime.
Parts of the project will also double as my thesis project,
So a gut feeling isn't enough to argument a choice upon
Therefore I gathered and composed a list of 70 engine with specs
To choose through a set of demands.
I'm sure every builders goes through this, so I would like to hear about your experiences
please.
I would be happy to share the list
or the list of demands.
But this is a locost spirited build... so plentyfull and cheapish donors needed
MikeR - 8/12/13 at 02:16 PM
what fits, is cheap, can get through iva and isn't a nightmare to wire up - engine choosen.
drt - 8/12/13 at 02:34 PM
:p
okay, thanks. I will make at bit more specific.
demands;
*less than 500gbp
*space ? transvers I4, V6
*best p2w
*reliable
I've thrown a BEC out of the equation
they are still in the list (pre 1995 engines for IVA reasons)
Oh, and I was under the impression that if gearb and engine was used from a certain model,
this was tested to that vehicle emission specs?
list;
Wankel mazda12a
Toyota 3s fe
Alfa v6
RX8 renisis
Toyota 3s fe SC
MG F 1,8K VVC
MG F 160 trophy
Honda VFR750 rc36 BIKE
Honda B16B
Honda K20A
Honda B20A
Honda B18
Opel C20NE
Opel C20XE red top
VW 1,8T 20v
Subaru impreza 2.0 turbo
Toyota 2ZZ-GE(vvtli)
Toyota ZZ
Toyota ZZ 2.0
Toyota celica vvti
Toyota 3sgte (turbo
Rover 620TI
Kawasaki twin 750SX power
Kawasaki tuned twin 750SX power
Honda H22 2,2Ivtec
Peugeot MI16 1,9
Peugeot MI16 2,0
Peugeot Gti-6
Peugeot 1,9 8v
Peugeot s16
Honda CBR900
Honda TWIN CBR900
Honda TWIN CBR900 Turbo IC
Renault N7Q-704 2.0
Renault L7X 3.0
Volvo B4204T5
Volvo 850glt
Volvo 850 2.3T T5
Volvo 850 2.0 20v
Suzuki GSXR 1100
Suzuki RF 900
Suzuki GSX750F
Suzuki GSF1200
Suzuki GSF600
Ford ZETEC 1,8
Ford ZETEC 2,0
Honda CBR1000F
Yamaha XJ1200 1993
MG F 1,8
After demands etc I have the category winners...
Overall
MG F 1,8K VVC
Honda CBR1000F
Ford ZETEC 2,0
Rover 620TI
Peugeot 1,9 8v
Peugeot Gti-6
Opel C20XE red top
Honda H22 2,2Ivtec
Toyota celica vvti
VW 1,8T 20v
price
Peugeot Gti-6
Yamaha XJ1200 1993
MG F 1,8K VVC
Peugeot 1,9 8v
Volvo 850 2.0 20v
Honda B18
Honda CBR1000f
Peugeot s16
p2w
Honda H22 2,2Ivtec
Suzuki GSXR 1100
Volvo 850 2.3T T5
Ford ZETEC 2,0
Renault L7X 3.0
RX8 renisis
Rover 620TI
Toyota 3sgte (turbo
and my favourite
Bangs per Buck
Yamaha XJ1200 1993
Peugeot Gti-6
Honda CBR1000F
MG F 1,8K VVC
Volvo B4204T5
Rover 620TI
Honda H22 2,2Ivtec
Ford ZETEC 2,0
Honda B18
ali f27 - 8/12/13 at 03:04 PM
H I surprised no duratec mondaeos are common and no kv6
MikeR - 8/12/13 at 03:05 PM
zetec and mg engines have been used in loads of kit cars there for problems already found and parts required made. do you have time and money to reinvent the wheel?
Ivan - 8/12/13 at 03:12 PM
I would go for the Subaru option -
+'s
It's Subaru , low CoG, ample cheap power, fore and aft alignment, gearbox can be adapted to transaxle, reliable, relatively light I think.
-'s
Fuel consumption, width, gearbox length.
chrism - 8/12/13 at 03:31 PM
MGF might be a good option for a donor as all the hubs are already setup for double wishbone use and setup for rear wheel drive, so no hub mods to make or adaptors required etc. Only issue is hubs have a slightly odd bolt pattern not one of the more common ones.
Plus also some people have swopped the Rover V6 engines into MGFs and they tend to be quite a good engine. (KV6 as mentioned above)
Subaru option is also interesting, but they do use the macpherson strut suspension so you would need to make some adaptors to change the top of the hub to accept a balljoint at the front and bush at the back, unfortuntaely the design means you cant use mushroom adaptors like the sierra hubs, but with the 4wd you could adapt the drive shafts to use the gearbox with the rear hubs for rwd and then cut off the CV joints on the front drive shafts.
drt - 8/12/13 at 04:23 PM
Hi guys,
thanks for the replys.
I came to the same conclusions.
the fixation is on the engine now, as hubs have been established.
I would also be running a quite wide track, so custom driveshafts I am stuck to anyway
And indeed I crossed out the Scooby because of the gearbox length.
I had some people telling me they -quite literally- hacked off the center diff and shortend it.
But have no data on how long it is then. (transaxle config)
The KV6 I like, the data I have suggest 170bhp and 155kg bare.
But they come with PG1 gearboxes, I heard they are prone to bearing failure
among the reason for doubting the 620TI despite the standard torsen diff
Duratecs are hard to come by cheaply (were I'm from)
[Edited on 8/12/13 by drt]
Volvorsport - 8/12/13 at 04:27 PM
if you were going to fit a 20v NA volvo , it should be the 2435cc version rated at 163 hp. not the 2 litre 140 hp.
drt - 8/12/13 at 05:01 PM
updated the list...
with the Kv6 and duratec.
the formula states the top 3 as;
1.8K
zetec 2.0
kv6
(shame on me)
I do not know much about the KV6,
does anyone have dimensions (give or take)
Does it come with a lovely aftermarket like the zetec and 1.8K ?
and will the pg1 cope with the extra torque?
big_wasa - 8/12/13 at 05:54 PM
The kv6 engine is a great engine up to 200bhp. You will get just shy of this with just breathing mods. Induction and exhaust where taken direct from a 2L. They sound great and pull like a train.
They do have a few faults but Hgf is not one of them. Cam belts are a dear job and the tools are not cheap to do it your self. The balls on the variable inlet manifold fail as do the viz motors. A new mani' is the best part of £500.
Clutch hydraulics are cheap and plastic but there are ways around this with Honda parts.
The v6 pg1 is the heavy duty box and will handle the torque just fine. It can be upgraded with steel caged bearings and a Torsen diff.
Don't bother to try and get much more than 200bhp unless you have deep pockets.
I love the zetec but its done to death.
The Gti6 is a great engine but it leans back and that wont help weight bias in a middy.
I love the Scooby lump but it will add length to the car.
I am going to look towards the Volvo if I can find a cheap low millage car
drt - 8/12/13 at 09:35 PM
Thanks!
Really nice, this is the sort of advice one can never have enough of
rdodger - 8/12/13 at 09:43 PM
K series 1.8 VVC
Because.... Engine is very light, powerful and reliable. Yes reliable with correct installation, thermostat position, head gasket etc.
DVA power for more .... well POWER!
PG1 gearbox is also light, various Elise/Exige ratios available and final drives. Elise gearchange is going to be easy to fit. Uprated bearings are readily available and not costly.
drt - 8/12/13 at 09:44 PM
btw,
a mate just offered his 'saab aero/viggen' opinion
Looks like a nice 150kg turbo lump...
...l'embarras du choix...
drt - 8/12/13 at 09:59 PM
Originally posted by rdodger
K series 1.8 VVC
thanks,
you're absolutely right!
K series is still in the running.
drove a mates K series R300 (road going) few years back and loved it.
He also never had the HG issues.
But as 'absolute power corrupts absolutely'
I find myself pondering if I wont go the extra proverbial mile
MikeR - 8/12/13 at 10:02 PM
different thing to think of. most engines end up on the same side as the driver. engines as usually a lot heavier than the gearbox.
Some japanese engines are on the passenger side thereby potentially balancing things out a little.
(this is based on you driving on the left)
rdodger - 8/12/13 at 10:07 PM
Having owned a transverse mid engine car (GTM Libra. VVC) I would say the lighter engine/gearbox the better.
Roll oversteer is not your friend!
drt - 10/12/13 at 09:52 AM
Very good point,
I will be looking into it right away
thanks
drt - 10/12/13 at 09:57 AM
vehicle dynamics wise weight is absolutely the enemy,
although COG of an engine can dial it out.
Butt I would suspect the double link rear suspension for that.
in the libra it is offset a little but instant centers will be on the floor.
Anyway, to make a judgement like that would require a great deal of study
and a complete data set on the libra... so maybe better forget I ever said anything
drt - 10/12/13 at 10:04 AM
yesterday,
drove 250miles and picked up my hubs...
brakes...
and calipers...
and had to pass the 'r300 friend' to order some spherical bearings...
turns out he just bought an aston martin v8 vantage grrr
the noise it makes hard to understand this is ECOG certified
drt - 15/12/13 at 04:25 PM
I recieved my 'tie-rod-ends' today
Had a lovely price for them.
Decided to put off the engine choice...
But I'm still very interested in what expierences you all had with different engines...
like general breakdowns or total blow-ups
In short what it is like to live with ... things numbers can't tell you.
Oh, and I have all the building/cad pics on photobucket... I'll post if anyone wants
rdodger - 15/12/13 at 04:31 PM
Yes get some pictures posted!
drt - 17/12/13 at 05:48 PM
The first building step
Getting tubes bent
laying it out
http://i819.photobucket.com/albums/zz120/motorsporteng/Home%20made%20Ariel%20atom/17_zps5985fea6.jpg
A rotisserie
1:1 scale plans plotted of the main spar tubes
Family happy with the space saving stance
going for donor parts (fist batch)
last tubes
it is very roomy!!
rdodger - 17/12/13 at 06:59 PM
Brilliant!
As you say it's pretty roomy.
How much larger than an Atom is it? The sides certainly look to be higher?
What's the expected weight?
Do you have it drawn in CAD?
drt - 17/12/13 at 11:03 PM
Wel it is about 10mm wider,
the side is about the same, but as it is now i sit lower
weight...
Started life as a BEC and was about 350-400kg.
now looking at car engis hope 490 as it looks now.
But I'll keep you posted.
The car is fully CADded up... everything from pipes to brakes from pedals to uprights.
most components were uptimiseded using FEM (FEA) (and a hefty safty margin )
Friday I am machining the 'weld on suspension brackets'.
I have to make them myself as I am using metric tie rod ends...
And the haynes/champion style brackets are imperial ofc so are he bushes.
drt - 17/12/13 at 11:04 PM
Oh and I TIG welded the whole thing...
wich was tedious... but welds are pleasing
iank - 18/12/13 at 07:02 AM
Hope that dressing gown is nomex
Looking good.
drt - 23/1/14 at 09:56 PM
It's been a while since the last update...
Since last time;
Suspension brackets have been machined.
Tie rod ends delivered
Coilovers tested and measured up... choice pending...
because a huge discussion has arisen with my former suspension prof.
Hubs have been refurbished.
And...
I made an engine choice,
It was daylight robbery when I picked up a Saab 9-3 2.0T
only 90K miles on the clock.
Standard low pressure turbo, hope to upgrade to something more substantial ...
But, it has the quite common gear selection problem... sorting atm.
[Edited on 23/1/14 by drt]
drt - 29/1/14 at 08:26 PM
Dear haynes,
I have loved and cherished your written words for years ...
But... with the Saab 9-3 codex...
you have completely and utterly got it wrong.
My improvements;
''when doing anything but a regular oil change or spark plugs on your Saab93
it is wise to sever your hands and attach on a large spanner.
Mind that a periscope is needed when wanting to see what you're doing while using
the 'hand-spanner'
If you do not have such a tool,
please go to chapter A1 to angle grind the car to bits"
drt - 14/2/14 at 01:06 AM
An update,
Suspension pivots nearly on.
Road wheels bought,
Custom set for slicks (just blind steelies)
Head skimmed, reassembling to test in the original car
drt - 24/3/14 at 09:36 PM
It has been quite a while since an update,
I apologize to everyone!
In the mean time I ordered some parts like;
nuts 'n bolts
engine parts
a short gearbox
electrics
tools
and made the wishbone (WIB) molds and started making the WIBs.
refitting the head
A front lower WIB, in its mold and pieced together
Stealing my welding table ? Well I'll just have to work in the kitchen than...
Drawing the WIB mold on the table and (center)punching it in.
A lower and an upper per table
A 800km return trip for a gearbox
drt - 26/6/14 at 04:24 PM
drt - 26/6/14 at 04:26 PM
drt - 26/6/14 at 04:34 PM
It has been a while
In the mean time I've build a hangar, garage was just too impractical.
So now most of the work goes on in their (the neighbours love me)
I had craig from plazcutz reallise my cad pedal box design
TOP Work I'll get some pictures soon
The saab is running again and waiting for the transplant.
Once that is done I would want to fit an eaton, any comments on this are greatly appreciated.
Gaz shocks and springs are on the way
quick rack, steering wheel, lights,... on the way.
Finish all the molds and infusing is now the biggest step left.
snakebelly - 26/6/14 at 06:06 PM
Great minds think alike? or possibly fools never differ? We are currently converting our Tiger GTA to take a Volvo 1.9T with an Eaton :-) boy its cramped!
Very impressive build so far, keep it up
[Edited on 26/6/14 by snakebelly]
drt - 27/6/14 at 12:22 AM
I can SEE the problem, the tiger engine bay is cramped for the volvo unit... full stop.
Please keep me posted on your conversion.
drt - 27/6/14 at 12:25 AM
Here is the pedal box... well (a) I took them out the box... and saw them just laying around, so sad...
So...
drt - 27/6/14 at 12:49 AM
The move to the hangar (not making a lot chronological sense sorry)
rear suspension, the brackets are this big so in the future I could always go back to polybushes... not ideal.
But in the front this means the Caster can be set from 0 to 10° without inducing bump steer
(angled pick-up points would cause)
samjc - 27/6/14 at 01:23 AM
Coming along nicely. Like the pedals could do with making my own.
drt - 27/6/14 at 01:40 AM
I have the cad files if you wish,
Or contact plazcutz
drt - 28/6/14 at 10:04 PM
I just love the postman... breaking his back on a non stop liveline of goodies
Quick rack
And front lights
cloudy - 28/6/14 at 10:36 PM
Steering rack look good - what's it from?
drt - 30/6/14 at 12:02 AM
It is for a dirt style racer.
I could send you one PM if interested
Very good price, but only 1 turn lock-lock... :s
[Edited on 30/6/14 by drt]
talkingcars - 8/7/14 at 10:51 AM
Sorry I am a bit late to the party but for the record.
Any K series engine (including the KV6) can be made to work as a mid or rear mount engine by using parts from the MGF for gear change linkages and for clutch control.
The 2.5L KV6 from a manual ZT190 is 185 bhp, other versions in the ZT auto, ZS and freelander is 175.
drt - 24/7/14 at 04:49 PM
As the say over here... take the next bus
For now I will stick with the saab engine.
As it already has some pressure on it, installing a sprcharger will be easy-ish.
p2w isnt too bad.
But never doubt a minute that the roverK (and others) keep me up at night
[Edited on 24/7/14 by drt]
drt - 24/7/14 at 05:00 PM
Checking the Cad model of the 'hammock' with reality... using custom tools
reality is a bit out
goodies from RD
Hammock mold
Later that night
Because of the shape, timber could be used for the sides... less sanding,filling and foaming
Finished...
Now a plug and then a finished article.
I would layer in alli strips to take the force while you get in/out the car...
This would save on materials,
any thoughts anyone ?
drt - 5/1/15 at 09:16 PM
It has been an absolute age!
Sorry for that, I have been busy.... busy...busy
But there is some news on the locost front...
It went on its wheels... but the bellcranks were flaud... made a bit of a scale fault.
Checking the measurements... both bellcrank, pushrod and damper must be in the same plane... a real pain on a curved car.
Harvesting the engine
Making engine mounts...
Next, the frame bracket
Very very tight fit
As in mm to spare
Had to tilt it a few degrees more the OEM... so the Diff would clear.
Gearbox mount... Bush mounted
Engine already leaving again... in order to drill the pivots for the bellcranks...
I'll make some pictures of the mounts in the future
Ofcourse in a very tight spot... this is just for the pilot hole, the rest was drilled through from the other side.
Also, the seats are in !
Hybrid driveshafts... waiting for welding
The new bellcranks !
coozer - 5/1/15 at 09:34 PM
Good work fella, just noticed this thread and I have another spoiler for ya..
Did you not consider a VAG engine? I'm taken with using a BAM 225 Audi TT or Cupra engine in mine, already 225bhp. 170 easy with a chip, good for over 300bhp standard...
drt - 5/1/15 at 09:45 PM
thanks, :p I did look at the VAG engine. They are quite expensive over here :s And when you find one, its mostly the 150bhp version.
Keep me posted And if you get the change, put it on some scales !
I might reconsider
drt - 23/3/15 at 09:28 PM
Work is a bit slow, as I am full-time on the drivetrain of a hypermiler vehicle for competition
A bit sad, but who needs sleep if spring is in the air... and 1/2 car in the shed...
Making the fuel tank (will be baffled)
Fuel tank fits lovely
Centering the hybrid driveshaft
New Seats in place !!! Really glad with these, as they will fit my royal behind, are still quite light and offer good support.
looks cosey, even with the non-removable ford wheel you can get in and out. The would walk way is to simulate the car's bottom
New pivots... finally
I can barely see where to put my feet ^^... this would work... but there is no real space for the steering column... especially because the pedal box will be moveable.
This Servo is SO big it's a bit of a problem... I am thinking of buying one from a small citycar (vivio) because they are 160mm in diameter instead of this 250mm whopper, although as these things work on engine vacuum... servo action will be compromised :s any suggestions ?
Original selector
reworked selector... non essentials had to go...
Tube will house electrics etc... shifter cables will come from beneath the seats it was the only option
The sitck will need some more length... shame I didn't build the seat bench myself... then the selector could have been closer Something for the Mk2
scudderfish - 23/3/15 at 09:38 PM
Why not just ditch the brake servo? I reckon most of the cars on here don't have one.
peter030371 - 24/3/15 at 08:23 AM
What he said
drt - 24/3/15 at 02:52 PM
I can see your point(s)
:p
I had the argument with myself, and several people...
If you do not instal a servo you have 2 choices (obvious sorry)
1) huge travel and low (required) pedal force
2) huge pedal force and small travel
Even if you would vary the master cilinder piston diameter
I have a autograss buggy thing, and although it only weighs 390kg you really have to STOMP it
if you want some stopping power... so much so that I am not able to heel-toe in it.
I know most -if not all- kitcars,locost do not have a servo...
So hom much pedal force do you have to exercise ?
peter030371 - 24/3/15 at 04:30 PM
My previous experience of a non-servo'd Striker (circa 530Kg plus me and the passenger) over 18 years of use is that a firm pedal pressure is required but I could heel and toe and I could lock the wheels if i got a little carried away/ over excited on the track The feedback was very good without a servo and I would have hated to have lost that 'feel'.
My current Striker still has not got an engine or brake fluid so no idea if that is worse or better
drt - 24/3/15 at 06:37 PM
Doing the maths comes up with 35.77Kg of foot pressure during 1G braking (idealized)
Sounds like a lot ?
piston diameter 0,048 m
Displacement brake pad 0,002 m
vehicle weight 500 kg
Braking 9,81 m/s^s
Braking torque, ideal brake distri, 1 wheel 927,936 Nm
Brake friction coeff 0,35
Saab 93 brake master cil bore 0,0238 m
pedal ratio 4,89
Mean brake disc radius 0,19 m
n number braking surfaces 2
Brake pad surface 0,005 m^2
Brake pad force 6976,962406 N
Pressure on brake piston 963904,5614 pascal (N/m^2)
force needed on master cilinder 1715,291053 N
Displaced volume brake caliper 3,61911E-06 m^3
Needed master cilinder displacement 0,813501871 cm
pedal displacement @ foot 3,97712026 cm
Pedal force @ master cilinder 174,8512796 kg
Pedal Force @ foot 35,76503446 Kg
coozer - 24/3/15 at 06:56 PM
Good work, just a quickie, how you going to route gear cables, water pipes and whatever round the fuel tank? Over, under or to the side?
Are you running the water pipes down the centre? That's assuming the rads going to the front?
drt - 24/3/15 at 07:26 PM
Gear cables are going over, electrics to the side (away from exhaust) and water... wel
I was planning on sticking a rad in a pontoon... and the intercooler on the other side.
Thus choosing mass centralization over ideal weight distribution.
scudderfish - 24/3/15 at 07:38 PM
Sounds like a lot ?
Braking 9,81 m/s^s
pedal ratio 4,89
Assuming you weigh circa 70-80kg, that is about the force you feel on the sole of your foot when you are standing up.
drt - 24/3/15 at 07:51 PM
I'll take that as a very optimistic compliment ^^
drt - 27/3/15 at 11:53 AM
So, I'm dumping the servo
thanks for the tips!
Now, this is the master servo.
How would you link that up? As the shaft does not describe a straight movement (due to pedal... etc etc you know)
A shaft with a 'spherical' end (ball) could work, but i'm scared about radial force on the plunger.
Because the saab converts the movement before the servo to straight (linear).
peter030371 - 27/3/15 at 12:29 PM
They normally have a clevis pin on the end but not sure how you would fit one to that master cylinder.
drt - 3/7/15 at 08:22 PM
During these last months I have been busy with our uni's ecomarathon team pushing 700 hours since February... besides normal classes...
Not a lot of time for personal indulgences
Machining the brake shaft so it works without the servo
finished product
A lot more room now XD
In the meantime trying to get the molds done... this is the airscoop
And this the bottem of what is going to be the bonnet mold
An overview, Thinking of housing the rads and IC over there ... mass centralisation and shorter water/air lines
Because of my geometry, this is the only spot the rack could be in :s
Bonnet mold almost there
And a delivery of brake stuff
drt - 14/7/15 at 01:48 AM
I've been waiting for news from RD for weeks
So, I'm doing detail work... front lights tonight
And the girlfriends car needs attention...
drt - 15/7/15 at 12:01 AM
Today... a day of angry phone calls
...rear lights
...and setting up the rotaxmax for a week @ Spa (promised the misses 'spa' don't think she really gets it though XD)
drt - 11/8/15 at 11:13 AM
So a whole week at the Spa Karting 25°-30°C and mostly dry.
Now she needs a top end rebuild, anyone knows somewhere I can get rotaxmax parts cheap ? Over here it's 500 smackeroonies... because you can only let it be done.
Build a small furnace... I got her up to over 1000°C, now i can cast my own ally parts.
First use was to make a ring for my girlfriend (had to make up for the Spa thing)... :p Silver is surprisingly easy to work with! and under the current raw silver price it was very cheap ^^
I have been waiting months for Rally design parts... really wondering if I would still place my orders there, the costumer service is a trainwreck.
Anyone having problems ?
To top it all I ran out of Argon, and over here all building sector and related companies are closed for a 3week builders holiday... no gas for me then.
Easing the pain with turning a gearknob
Thinking about using the Saab mirror glas in a DIY side mirror... because they are heated making life so much better when it's cold or starts to rain...
if they only weren't so vast.
Engine is in for the xxxxtime
drt - 11/8/15 at 11:25 AM
Oh, I have been meaning to ask.
The original atom uses separate front parklights/daytimerunninglights...
Looking at the model they are crystalight ?
If so, they only sell reversing lights... who would be way too bright/diffuse to pass an iva :s
Anyone knows what they are ?
see->
drt - 11/1/16 at 11:16 PM
It's been a while
testing the look in real life for the first time... before starting making the molds and ultimate products
vast amounts of resin, glass- and carbon weaves arriving along with corque sandwich material... postman sure loves me :p
sanding all the wood models for the last time before the varnish coat(seallent)
making parts for new steering arms... as the original ones had dreadful Ackermann, even without the change in wb and track
For a long time I was planning on using an LED as an reserve fuel warning light, just by adding resistors so that when the float reaches zero (aka lowest resistance) the power in the circuit would be +- 5v... a very simple, light and elegant solution... but turns out LED's aren't as picky as I thought... the lit up as soon as 1.5v getting ever brighter,
too bad... have to stick in a gauge
And then this disaster, I was planning on using the Saabs fuel pump as a piggy-back on my tank... turns out a Saab has just the one pump in the tank.
Thus it has internal passages to avoid air bubbles (it's a rotary pump, can't suck air) These are impossible to close of, so can't use the pump outside the tank... need to use the whole original plastic nightmare or buy a specific new one.
Keeping it locost by reworking the tank so to use the original.
This needs a bigger hole and bigger lowest fuel gathering compartment.
needed to go to, because of packaging the fuel nozzle is moving to the other side
To add to all that, I've just ordered jet cutted parts the week before; So I'll make the pump fitting the old fashioned way
The lid
the new set up, not very pleased with this
My tank is much higher than a Saab one, so this had to be lowered to
Now I'm waiting for some quite days to do all the composite work in one go
drt - 14/1/16 at 12:59 AM
took her out to clean the hangar
peter030371 - 14/1/16 at 08:11 AM
Looking good, we have all sat in our chassis at some point and gone 'brum brum'
drt - 14/1/16 at 01:20 PM
Getting very eager to get to do it for real
jimmyjoebob - 14/1/16 at 05:28 PM
Build looks great - what make are the seats you are using and how much do they weigh?
drt - 1/2/16 at 11:26 PM
Sorry for the late reply.
I got the seats here;
,2 x BLACK BUCKET SEATS. PLASTIC 4x4 kitcar, beach buggy, Boat.
Very good service ! very good seats... I must warn that they are BIG...
much much bigger than the GFRP's I had (kitspares type ones).
But fit me very nicely !
But you'll need some space in your vehicle.
I didn't weigh them yet, the fabricator states 7.5kg a pop.
drt - 17/2/16 at 12:20 AM
repositioned the gear selector again, somewhat higher and more back... much more ergonomic and now with a tiny throw
postman came by
I couldn't help myself XD
love the sound dampening qualities
I don't believe you guys have this in the uk ? Cheap as chips! and works so good... it could strip the grease of a steam engine
the end of another late night
spot the pun... it was only a matter of time this washed up
After a lot of careful cutting and consulting the cad model...
exhaust completed... now only wait for 2 Vbands to come in and weld it all up
drt - 17/2/16 at 10:17 AM
tips on how to polish the dull stainless pieces to suit the mirror finish of the damper, please do not hesitate
drt - 4/3/16 at 01:24 AM
Who needs a lasercutter when you have a nice angle grinder
The new gearselector in place, I'll be adding some structure to it later to give it lateral stiffness... and remove the now obsolete parts
drt - 3/4/16 at 10:42 PM
I have been busy with a lot of things, in the meantime I did the gearshift (gearbox side) pics will follow... and placed the radiators...
This might be surprising
SO... I machined some spacers to make a Rad Sandwich... these fit the plastic bobbins on the rad, the same system applies to the suspension of the sandwich.
I prefer it that way hance the small (4mm ish) screws in the plastic are now only in tension instead of in shear like with most :s
Also the plan to put them in the side pontoons got scrapped... pontoons needed to be way to big, so now the'll house the inter- and oilcooler.
drt - 2/5/16 at 12:18 AM
The Gear selector... I ended up buidling models up to MK3,
MK1 being direct action... but in the friction/stiction-less world of CAD these things work, in reality it was one big jam.
MK2 being the picture below with a direct acting push/pull for sideways motion and a non rotationally fixed mount for in/out motion.
Because of space restrictions (exhaust) the motrion could nog be lineair ... locked up yet again because of friction and created moment on the gear shaft... thus binned
MK3 Is this one, using a lever action directly in line of the required force for in/out movement.
Had to lathe a thingy to attach the tie-rod-end center shaft
AND WE STARTED LAMINATING...
Tricking a large part of the family in participating
We started with the "hammock" between the front wheels
Despite using several coats of boat lacquer on the wood model... and sever coats of PVA some parts still bounded
It was hell getting her out... destroying the model in the process.
For the other models I'll be using my secret weapon.
drt - 3/5/16 at 09:25 PM
We continued these last days with laying up the mold on the model of the “bonnet“.
This one needed a double amount of layers to make it stiff enough..
That meant tapping, tapping and more tapping...
Luckily I have some reinforcements...
In this shot the 'secret weapon' is visible... insulating aly tape
Works a charm, out in 10 minutes
a mirror finish
And even the model survived unscratched this time
And because of the team effort I had to make a task black board... very 6sigma
drt - 7/5/16 at 01:09 AM
Taping the hammock model
A very flash gordon airscoop model
drt - 15/5/16 at 08:32 PM
Today we've build an airscoop mold
It's a real family affair...very thankfull of that! it means we can make a mold in a few hours... the banter, that's free
shouting how things should be done... running in the family
drt - 25/7/16 at 01:11 AM
it“s been quite a long while...
my TIG broke down, wtf paid nearly 3000 quid for it only 5 years back ! Been dry+warm stored and only used on the weekend.
Ofc they wouldn“t tell me what was wrong, had to wait 2 moths for the damn repair.
So starting where we left off...
The mold for the nosecone
Hammock mold
making th mold stiffer, as it is quite big. This was a real faff !!! The resin would not stick to the wood and spur bubbles all over, drove me insane
So this was the result, ugly as fa... but it does the job...
It got to me so bad that I“m splashing cash to do the “products“by vacuum injection.
And this is thanks to ma genius... an old motorcycle fuel tap now serves as a 3way valve for getting argon to the TIG, the weld piece or both.
Because we're finally tigging the stainless bits
With the help of some lathed wood
This almost doesn't look like a huge bodge
As by magic... Tadaaaa finished
And then I made a new tank out of ally, as the steel one weighed a tonne.
Since I only rarely weld ally I was quite pleased... and then I saw Project binky yesterday... one can only cry
This morning we started demolding the hammock... again a moment of terror... despite using the ally tape making the surface so smooth that even the PVA cant be polished up because it rubs strait off... and ofc the PVA who's only goal in life is to DEMOLD the damn thing... it would not come out for sh*t.
Again a model had to be destroyed
3hours of blood sweat tears and curses got it out
drt - 26/7/16 at 02:20 AM
anyone any tips on polishing stainless exhaust? ally tank ?
drt - 27/7/16 at 12:51 AM
some time ago I was asked how I would run the cables, cooling etc in the car.
well, I've created this...
For the water I've chosen to run a pipe through, I had considered running it directly... but didn't trust the fuel acting as an accumulator.
shifter cables and wires are going through also.
Lately we we're having an itch epidemic, with everybody moaning and scratching S. Holmes came to the conclusion the problem was the wash cycle in conjuction with GFRP The culprit was punished to very old fashioned laundry days...
drt - 6/8/16 at 12:45 AM
So the tank is in...
I adapted the brace to be bolted... I'm foreseeing a tie rod end connection in the future, but for now...
So the tank rests on the brace and is strapped to it. Sideways movement is halted by little brackets on the frame.
Now just need to paint it and then find some self adhering foamy bits...
drt - 5/9/16 at 11:20 PM
So in the meantime a lot of sanding molds...
I really despise doing it, but anyhow not a very informative picture for you guys XD
Tonight finished the gearshift... best throw ever, about 30mm :p
Downside is that the selector needed a bit more stiffness...
The opening is needed to reach the connectors, will give it a think how to stiffen that part. As obviously this is now the weak point
The shifter end... looking at it from behind... remember that the Saab has a rod acting directly upon a shaft while I now have a cable selector...
So I needed to invent this from scratch
A rod end pulls and pushes the shaft via an adapter that als has an arm for the rotary motion.
The push-pull cable for the rotary motion is hung by a pivot as the in/out motion of the shaft is far greater than the cable would allow.
drt - 5/9/16 at 11:27 PM
Last year I spent August on the track...
this year could not have been more different, though still had wheels
sprintB+ - 6/9/16 at 07:46 AM
Good to see you back, I did wonder where you had gone. excellent work, well done, keep us posted
drt - 6/9/16 at 10:33 PM
Thanks sprintB+
btw I have found some products for the anglegrinder to polish stainless and ally
Sundaydriver - 18/9/16 at 11:42 AM
Great thread, loving your efforts, I'll check in again 👍
drt - 18/11/17 at 02:53 AM
[img]1[/url ] by [url=https://www.flickr.com/photos/141082768@N04/]paris r, on Flickr[/img]
[img]1a[/ url] by [url=https://www.flickr.com/photos/141082768@N04/]paris r, on Flickr[/img]
[img]2[/u rl] by [url=https://www.flickr.com/photos/141082768@N04/]paris r, on Flickr[/img]
[img]3[/u rl] by [url=https://www.flickr.com/photos/141082768@N04/]paris r, on Flickr[/img]
4 by paris r, on Flickr
5 by paris r, on Flickr
6 by paris r, on Flickr
7 by paris r, on Flickr
8 by paris r, on Flickr
8a by paris r, on Flickr
11 by paris r, on Flickr
11a by paris r, on Flickr
12 by paris r, on Flickr
14a by paris r, on Flickr
15 by paris r, on Flickr
17 by paris r, on Flickr
18 by paris r, on Flickr
19 by paris r, on Flickr
20 by paris r, on Flickr
21 by paris r, on Flickr
22 by paris r, on Flickr
[Edited on 18/11/17 by drt]
drt - 18/11/17 at 03:08 AM
24 by paris r, on Flickr
25 by paris r, on Flickr
26 by paris r, on Flickr
27 by paris r, on Flickr
30 by paris r, on Flickr
36 by paris r, on Flickr
37 by paris r, on Flickr
38 by paris r, on Flickr
40 by paris r, on Flickr
41 by paris r, on Flickr
43 by paris r, on Flickr
44 by paris r, on Flickr
45 by paris r, on Flickr
47 by paris r, on Flickr
48 by paris r, on Flickr
49 by paris r, on Flickr
50 by paris r, on Flickr
51 by paris r, on Flickr
52 by paris r, on Flickr
56 by paris r, on Flickr
57 by paris r, on Flickr
58 by paris r, on Flickr
59 by paris r, on Flickr
60 by paris r, on Flickr
61 by paris r, on Flickr
62 by paris r, on Flickr
67 by paris r, on Flickr
72 by paris r, on Flickr
74 by paris r, on Flickr
drt - 18/11/17 at 03:10 AM
75 by paris r, on Flickr
76 by paris r, on Flickr
77 by paris r, on Flickr
78 by paris r, on Flickr
79 by paris r, on Flickr
83 by paris r, on Flickr
85 by paris r, on Flickr
86 by paris r, on Flickr
87 (1) by paris r, on Flickr
drt - 18/11/17 at 03:14 AM
87 (2) by paris r, on Flickr
88 by paris r, on Flickr
89 by paris r, on Flickr
90 by paris r, on Flickr
91 by paris r, on Flickr
95 by paris r, on Flickr
96 by paris r, on Flickr
101 by paris r, on Flickr
102 by paris r, on Flickr
103 by paris r, on Flickr
104 by paris r, on Flickr
105 by paris r, on Flickr
106 by paris r, on Flickr
107 by paris r, on Flickr
108 by paris r, on Flickr
109 by paris r, on Flickr
111 by paris r, on Flickr
115 by paris r, on Flickr
116 by paris r, on Flickr
117 by paris r, on Flickr
drt - 18/11/17 at 03:17 AM
118 by paris r, on Flickr
119 by paris r, on Flickr
121 by paris r, on Flickr
124 by paris r, on Flickr
126 by paris r, on Flickr
129 by paris r, on Flickr
133a by paris r, on Flickr
134 by paris r, on Flickr
135 by paris r, on Flickr
136 by paris r, on Flickr
138 by paris r, on Flickr
139 by paris r, on Flickr
145 by paris r, on Flickr
147 by paris r, on Flickr
151 by paris r, on Flickr
152 by paris r, on Flickr
154b[/url ] by [url=https://www.flickr.com/photos/141082768@N04/]paris r, on Flickr
155 by paris r, on Flickr
drt - 18/11/17 at 03:20 AM
156 by paris r, on Flickr
157 by paris r, on Flickr
158 by paris r, on Flickr
159 by paris r, on Flickr
162 by paris r, on Flickr
168 by paris r, on Flickr
174 by paris r, on Flickr
172 by paris r, on Flickr
175 by paris r, on Flickr
177 by paris r, on Flickr
180 by paris r, on Flickr
181 by paris r, on Flickr
184 by paris r, on Flickr
191 by paris r, on Flickr
186 by paris r, on Flickr
188 by paris r, on Flickr
189 by paris r, on Flickr
drt - 18/11/17 at 03:34 AM
Well, thanks for that photobucket... no new stuff gents.
I have had the worst 2 years of my life...looking for internships trying to graduate.
Monday I have an interview with Prodrive, any help welcome.
Also still without a car since looking to be an (unpaid) intern means little dosh coming my way and it didn't help that the tax regime for the daily I was doing up went up by a 1000% (no joke) 3 weeks before I finished it, so started from scratch with another daily.
meanwhile the Saab engine has left the shop.
Over the summer the company that made the ECU interfaces for the TRIONIC disappeared, so that meant that for it to run in the Atom I would had to invest in a standalone ECU thingymabob...
and despite what the guys at MCN say, an Emerald does noet a budget build make.
And the engine was too heavy anyway, since it's becoming abundantly clear that this rotten country will never let me have it on the road.
So it needs to be a 750kg trailer/car combo so I can tow it to the track... leaving about 500kg ish for the car.
So I looked for -and found- the best engine ever made
A rover K
I would like to put bike carbs on it ( multiple reasons) but I guess I'll keep it standard till I get it running
big_wasa - 18/11/17 at 07:32 AM
Now if that donor had the 2.5 kv6 that is indeed a cracking engine.
drt - 18/11/17 at 11:41 AM
Srr mate...
just a 4 pot...
:p current budget, total weight and dynamic reasons.
kitman - 3/12/17 at 08:05 PM
Are you putting it on the road when it's finished?
ettore bugatti - 3/12/17 at 09:38 PM
Good choice!
Original Atom was also build with the K-series.
drt - 4/12/17 at 01:30 PM
I'd love to put it on the road, but it seems mine is the worst country in the world for such a thing.
So euhm I have a little route around the leg.
Thanks I always loved the roverK, it should bring me to -500kg now... that will allow me to trailer it (750kg)
drt - 14/1/18 at 10:24 PM
So
Finally started on extracting the K-series...
And doing other stuff in the lid workshop during the long evenings.
For the sake of honesty ... when I designed the car I never had never seen the uprights but had parametric kinematic designs for the placements of pick up points... in my stupidity I guesstimated the location of the steering arm.
And that bit me in the ass as later appeared that the only bumpsteerless route was through the chassis member
FFS
[img]
[img]
Because of the top A arm interfering I can only reinforce the bottom and cross brace above... a bodge... But I can see no other way
drt - 14/1/18 at 11:33 PM
Why so little progress ?
In 2017 me and my daily where taken of the road by a hit and run.
With no funds I set out to get a cheap daily, had to restore one in the end.
Finished I was faced by sudden a 10 fold road tax increase and was priced out.
Sold it at the original price despite the resto because the market had caught on to the tax regime.
With only commercial vehicles exempt from the tax man (yeey capitalism) I had to try for a van...
A T4 was the only thing reliable and in budget... well in this state
So on top of that new brakes, turbo, suspension, bumper beam, back garden respray, fuel pump and other weld work ... we're mobile once again.
2017, I won't miss thee
drt - 22/2/18 at 09:10 PM
Engine out today
After cleaning
threw away the ancillary's... now how to route that alternator ?
drt - 15/3/18 at 10:15 AM
So, the alternator bracket thing for a non-AC set up arrived.
In the process of fitting the engine...
I was a bit gobsmacked that the roverK is bigger than the saab B204/205 !!
The belt drive camshafts are a cause I presume, but in all rover choose toe make the engine wide and low, while the saab's was fat, high and narrower
I don't get why people buy new belts, works fine
Starter position is not helping me
drt - 12/4/18 at 10:42 PM
soo putting in the RoverK in...
I was getting worked up about having to weld driveshafts again so decided to tackle the suspension issue first.
because -those who followed- there is a large chasm in the front chassis member to let the steering arm go through.
The only solution is to give the suspension a parallel geometry, since then I can move the rack around without causing bump steer.
So I was gonna go for that... screw the camber comp...
Since that meant I might had to redo the wishbones I was thinking to narrow the track (1600mm now) to accommodate the
OEM rover 45 (track=1475mm) wishbones
(saving me that heart ache as well)
BUT i stumbled upon the most wonderfull thing!!!!!!!!!!!!
While trying to fit the driveshafts it became clear the rover 45 CV's wouldn't fit the MGF hubs.
Crying out loud I -while swearing- fitted the MGF CV's on the Rover shafts... and lo and behold...this combo apparently takes the track to
1590mm
So problem solved since there is enough adjustment in the current wishbones and in the gearbox side CV.
So now making new suspension pick-up points
drt - 16/5/18 at 03:45 PM
Ok so nobody impressed by the wideness of the rover MG combi driveshafts...
Been trying to fit the engine for weeks... but keep struggling to find the best compromise.
The more you know the less you know, it's a curse
Bodged a load spreader bar the easily level the engine.
Still added 4 ratchet straps to change the inclination on the go.
But now not sure about how the engine will take the angle
drt - 19/5/18 at 12:02 AM
So I went with the 11.1 degrees in the end...
Finally started fitting...
Machining a stud with M12 thread on one side and M10 smooth+threaded on the other
Why?
So it will fit the engine and the take the bushings I have
After much consideration decided to fit the bracket this way as it was easiest to (re)fit an engine this way
Gearbox side
Going ...nuts... doing these bolts up 20 times an hour
Lower mount tagged on in situ and now being welded fully.
A machined steel bushing temporary takes up the space of the rubber one... makes fabricating much easier and beats burning rubber
Gearbox side fully welded and rubberised
Lower side finished
Gearbox side brackets... who needs a laser cutter anyway
Like zoo
Started on the third and fourth engine mount... more on that tomorrow
drt - 23/5/18 at 12:00 AM
A little word on the engine mounts...
I see a lot of people use the PU tophat type suspension units, and those are waaaay to stiff to filter any vibration.
Even so if you do the arithmetic, given the frequencies of an engine and a stiff light frame, it is very hard to isolate the one from the other.
Must make sure the sprung doesn't touch the unsprung
I wanted the Rover fuel pump as to keep things together, for a multitude of reasons.
Ofc you can't get to the tank from the interior... Grrrrr... out with it than
The last mount
Some CAD
Mocked up
Welded
Done...
Now she's going on the ramp again so I can clean up and clear the cave
drt - 25/5/18 at 06:22 PM
As you can see the cave needed some attention... made use of the car being out to set up the ramps
She is on the ramps again... far better to work standing up
Still a mess, although the floor is hoovered.
I'll get you guys an after picture as well.
Since it was such a nice day today I thought to strip the harnas from the Rover.. as in not to be cooped up.
My mistake... what an absolute pain in the ...
Thanks rover for hiding it behind EVERYTHING... trim, heater, pedalbox, you name it, it's out.
So just a quick bite, upload photo's and on with the jungle of wires...
As I see it, and please correct me, the MEMS just needs the key-fob-detector-thing and power going to it from the interior side of things?
The engine side is a separate connector... so not involved in this discussion.
drt - 12/6/18 at 11:53 PM
Sooo after going through wires upon wires like a hairdresser trying to separate the interesting ones...
I gave up, searched for the diagrams and came up with these.
5AS
MEMS3 pinout
Soo, got rid of the lot and going to make my own loom... debating sticking the keyfob to the detector to avoid the burden.
But then again, it is an excellent anti-theft device
After giving up on that I ran into some older atom pictures and noted that those didn't have elaborate seat structures.
Given that my seats are cheap-will-do-for-nows and are not self supporting I started playing with the idea of altering the existing set-up.
What used to be...
I got get rid of about 30kg of weight while losing some Newtons/degree... since the emphasis has changed to keeping it light, I went for it.
Thinking I would not change the seat position I replaced the old bottom up design for a hanging one.
But then i realized that I had more room under the seats and could get the COG lower... Since we are talking about 200kg of weight fully laden this is not to be sniffed at dynamically speaking.
The most radical seat position won some 15cm in max. height and some 10 in COG.
Making brackets again.
So this is the new position. With this position it is impossible to put weight on the 'hammock' style bodywork. So this is now going to be lighter, thinner and cheaper to.
For comparison
For the gear selector I'm thinking of laminating a bulge in the hammock... or going with a DIY electronic shifter.
Also I have been paining myself over the radiators, they are a packaging nightmare.
Since the now live where a lot of other stuff could be neatly stuffed.
Bought these Polo rads cause they were cheap and the locost standard, but actually to big to live in my nose cone.
Been searching.
CAR l x h x d in mm
Micra K11 1.0 380 X 370 X 17
Panda 45pk 1992 0.9 462 x 240 x 35
Panda fire 1994 520 x 250 x 34
Punto 55 1.1 1993 435 x 322 x 23
Deawoo Matiz 0.8 458 X 294 X 16
Fiat Cinquecento 0.7 31pk 312 X 214 X 24
Fiat Cinquecento 0.9 41pk 248 x 465 x 34
VW polo II 1986 1.0 40pk 380 x 322 x 38
VW polo III 1.0 45pk 430 x 322 x 34
Civic V 1.3 75pk 1995 346 x 346 x 24
saxo 390 x 322 x 23
Opel Agila A 1.0 377 x 378 x 34
Subaru justy 2001 1.3 330 x 350 x 16
Panda 1986 583 x 250 x 34
UNO 1.0 1992 312 x 340 x 32
Alto V 1.0 2000 325 x 360 x 18
swift 1.0 2001 408 x 341 x 34
Now the Cinquecento 0.7 one would be excellent, well 2 of them in front one another anyway.
But they are quite rare, even new, 0.9 was way more popular but it's too wide.
95 Civic Might be the best compromise, looked at rover mini's but they are 5 times the price.
Thoughts anyone ?
Next steps... a complete steering system overhaul
drt - 14/6/18 at 12:47 AM
So tonight the steering system
As the geometry changed the location of the steering rack was no longer correct.
And there was the little thingy with the pesky Pauli principle regarding a steering rod and a chassis.
So to keep it simple the steering rods will be in the same plane as the upper wishbone.
This means the inboard pivot point must be on the same point along the X-axis.
Since the steering rack pivot point combo I was using is about 25mm to wide at the narrowest setting it meant...
Bodging time!
Steering rack without pivot points
The pictures I took of the process didn't go through for some reason. But is was a simple case of putting it in the lathe,
taking out the dial gauge, swearing for an hour to get it somewhere near concentric along its length,
machining off the threaded ends, boring a hole and tapping it.
Result;
Now I'm gonna run some simulations to see if my assumptions regarding the Ackermann and bumb-steer are still correct.
drt - 15/6/18 at 11:44 PM
few days of careful progress, calculations and simulations.
Trying to get the steering rack in the best position and minimising bump-steer.
So first some very quick and dirty simulations to check the maths and quickly alter the set-up.
This used to be the home of the rack and rad... it's all on its way out.
So firstly setting up the rack so it is exactly the width of the top suspension points, done that by putting the bolts through.
Because fabrication tolerances XD
2 little profiles, drilled and installed. Now scribe from the back where it needs to be cut.
Installed
A new steering down tube, with some recesses to increase the weld area and have a mechanical way of transmitting the torque.
So that is operational, kinda low on pedal box space... but we'll pas that bridge in due time
So now to hide my shame
10 minutes of cardboard and 10 minutes of grinding later.
Set the TIG to 11
Had a look at the files from way back when... to establish the steering-arm.
Sorry for the lingo in these notes, I tend to go between a fair few languages. So after establishing the Ackermann angle followed the minimising of the bump steer and combining that with the space in the rim, I got the lengths of steering arm I could get away with.
This now remains a choice of steering wheel torque vs. turning circle.
drt - 16/6/18 at 09:39 PM
Not a lot today...
watching the start of the 24h... and listening to radiolemans in the shed does that to a man.
Hiding the shame on the other side
And pulled this out of a the heap...
Mini 1300 high volume rad.
I'm thinking of using it, but I recon it will be on the small side.
opinions ?
drt - 20/6/18 at 09:30 PM
Continuing with the steering arms.
Machined some parts.
Fixed to a little weld mold. Need some more parts before I can finish them.
Last new pick up points
Out with the old
In with the new
Added sides and done.
AdamR20 - 21/6/18 at 08:38 AM
You're nuts, I love it!
Rad looks a bit small to me too. Will a Polo one fit? Works fine on my 1800 Zetec with 185bhp.
drt - 21/6/18 at 09:21 AM
Thanks... I think XD
Well, I've been down the polo rad road (see above) and it was a packaging+flow nightmare.
The car either needs one just the right size so it fits the front
see...
Or in sidepods like the oil coolers of the 500.
Thanks for the reply, I was starting to think people lost hope
AdamR20 - 21/6/18 at 09:25 AM
Give it a try with what you have, with good ducting and low % of antifreeze it may work. You could also stick an extra bit of cooling in afterwards (such as a heater matrix or small motorbike rad in a side pod) if needed.
drt - 21/6/18 at 09:35 AM
Using the rover K I'm a bit nervous on just trying.
But simulating a radiator is a real pita... there are so many unknowns
But your heater matrix idea sounds elegant. Small enough to fit in a sidepod and plenty available.
I dismissed matrices because I thought they are high resistance for coolant and optimised for slow air flow, no ?
AdamR20 - 21/6/18 at 09:38 AM
I'm not certain - but - to me that sounds like a beneficial condition perhaps. If the water spends more time in the radiator it will get cooled down more I suppose, if it flows through fast it won't have time to cool down!
Edit: Maybe it could be 'branched' off the main coolant hoses a bit like an actual heater matrix to prevent poor flow through the main cooling system, then have a fan hooked up if there's poor air flow. When I've taken 'normal' cars on track having the heater on full blast does seem to make a different to water temp.
[Edited on 21/6/18 by AdamR20]
drt - 21/6/18 at 10:25 AM
The slower the flow of a heat exchanger, the nearer the temp of the fluid can reach the temp of the air.
But the less efficient it is, it's a case of what you need.
Like a household radiator is huge and slow... so it can give of almost all the heat in the fluid (limited by convection and a bit of radiation).
But a car radiator is optimised for high flow rates of both the coolant as well as the air, so it can efficiently lower the coolant temp from EG. 100 degr C to 80C in a small period of time.
Because the flow rates are very high in the end the total amount of energy expelled is much higher than the slow one, this is also because the heat exchange rate is not linear.
Q = + (m1)(Cp1)(T1in - T1out)
Q = + (m2)(Cp2)(T2in - T2out)
DTlm = [(T1in - T2out) - (T1out - T2in)]/ln[(T1in - T2out)/(T1out - T2in)]
Q = U A DTlm
It's always a case of the more you know, the less you know
But nonetheless, still going to try
drt - 21/6/18 at 09:19 PM
DAMN...
Pushed my luck on this one.
The weld mold was insufficient for keeping the parts in place.
Didn't help that the tolerances for the connection with the upright is about 0.5mm
So now I'm going to have to get them milled... a bit of a bugger since it's going to be costly judging by the details.
Ofc everything is relative, but atm the whole project has only cost me around 1200 eur.
Any machinist out there ?
woodsy144 - 20/1/19 at 10:08 AM
Hello,
I am interested in your steering rack.
May I ask, where did you source it from??
Make, model, donor, etc??
Tim
drt - 12/4/19 at 11:39 PM
So after not even being in the same country as the project for a long long time, where back
In last episode, a dog's breakfast steering arm... that didnt work.
now she has 2 machined ones... only 0,1 degree bumpsteer at max deflection and very nice ackermann.
But, in a weird twist of faith, again there is some chassis in the way.
So out with the grinder
[img]216 (2) by paris r, on Flickr[/img]
Some newspaper aided design.
[img]217 (1) by paris r, on Flickr[/img]
Grinded
[img]217 (2) by paris r, on Flickr[/img]
Installed
[img]217 (4) by paris r, on Flickr[/img]
then invented some bracketry to put the alternator somewhere where Rover didn't think off...amateurs
[img]216 (5) by paris r, on Flickr[/img]
Exhaust is being rerouted atm, pics tomorrow. Gave me a headache for the longest time, as NA-engines.. you know the drill.
Brake lines are made and ready to go in.
I'm hoping to finish the bl**dy thing now...
wish me luck
drt - 17/4/19 at 07:55 PM
Original flanges didn't fit, so made some to work with the OEM gasket.
so that makes the front part...
And then... watching the grand tour Mongolia, I was laughing that the mistaken steering rack position must have been scripted...
Until I found out that I did so too months back... pays to sometimes sit in it and make noises. So new steering rack position requires new mounts...
Spacers
so all together...
Positioned correctly,
Installed
lovely jubbly
So on with the gear shift... found out the MG F cables do not fit the Rover 45 gearbox ball joints... what a joke! It's the same friggen gearbox.
Looked to get some locally, no dice. Looked on the confuser... 15 QUID !!! for 1. So I set out turning one
Horrible job, but it works... spare the phallus jokes
[url=https://flic.kr/p/2fz2ade]
So now onwards to instal the gearshift.
