Which alternator
Streetfighterpete - 8/11/14 at 02:27 PM
Hi guys,
What size and type of alternator should I be using on my Luego. I'm fitting a 2.0 Zetec black top engine with bike carbs fitted and the existing alternator is too large. I'm obviously not running power steering or air con, so I'm assuming I can run a much lower rated alternator? I bought a retro ford alternator for a RWD Zetec conversion, but this is also too large. Any advice, pics and details much appreciated - has anyone got a suitable unit for sale?
Pete
blakep82 - 8/11/14 at 02:32 PM
One of the denso ones as used on most japanese cars, kubota tractors etc, small, about 45A output should do the job
big-vee-twin - 8/11/14 at 02:58 PM
This is the one linky
As said before you will find the same on Diahatsu Charade cars. Have a look on eBay there's usually a few on there.
Andybarbet - 8/11/14 at 04:26 PM
I picked up one from a Bedford rascal van, looks smaller than the zetec but ive not made a bracket yet so can't confirm if it will fit once the throttle bodies/inlet are on.
I can measure the alternator in the morning if it helps ?
I paid £15 for it so new old stock so quite a bit cheaper than a denso, unless you get a lucky bargain on ebay.
Keep us informed on how you get on, i would also be interested in the bracket & where/how it mounts under the inlet ?
I had to make up an Ali spacer to allow the zetec pulley to fit onto the smaller diameter shaft.
Rascal alternator
Rascal alternator
pulley & spacer
pulley & spacer
[Edited on 8/11/14 by Andybarbet]
big_wasa - 8/11/14 at 05:22 PM
Denso's are around 40A and as small as you will find.
So small they fit them to some bikes and that's where I got one from for my latest project.
My last one.
SPYDER - 8/11/14 at 06:52 PM
Theres one finishing very soon...
KUBOTA / DENSO ALTERNATOR 12v 40amp
And another...
Alternator - Aixam 500 diesel 2001
[Edited on 8/11/14 by SPYDER]
Streetfighterpete - 8/11/14 at 07:59 PM
Guys,
Thanks so much for all your advice. This is such a great forum for those of us who don't have as much experience as others. I'm going to look out for one of the small Denso units. Watch this space!
