Are propshaft supports needed?
Piooly - 15/5/15 at 12:54 PM
Do you need supports for the propshaft for the IVA test? The ones for if your propshaft came off...
My test is in a couple of weeks and I would struggle to add them..
thanks
MikeR - 15/5/15 at 01:14 PM
no.
Smoking Frog - 15/5/15 at 01:19 PM
Prop catcher? No don't think so.
theduck - 15/5/15 at 01:30 PM
Nope, but still worth fitting them if you can.
joneh - 15/5/15 at 01:36 PM
Not needed but I'm fitting one each end. Don't think 1mm of alloy plate will stop 7kg of 6000 rpm ripping through my leg if it lets go!
Slimy38 - 15/5/15 at 02:04 PM
It is disturbing how an obviously effective safety device is not included in IVA, but a sharp corner that a pedestrian might graze their leg on is an instant fail...
adithorp - 15/5/15 at 02:09 PM
Not an IVA requirement but a good idea if you can fit. Just needs to be enough to keep the prop close to aligned to prevent it flailing.
