Gear Lever IVA Compliant
Stevie_P - 9/5/18 at 04:13 PM
Hi All
Suspect not but can you tell me if my gear lever below is IVA compliant?
If not, how have you chaps overcome these sort of issues?
Gear Lever
Gear Lever
Nickp - 9/5/18 at 04:28 PM
Stick a bit of rubber hose over it
Stevie_P - 9/5/18 at 04:39 PM
I thought it had to look permanent?
Not sure a bit of tube over would pass as that?
nick205 - 9/5/18 at 04:45 PM
Fit a bicycle handlebar grip like this with a locking collar. Modify the locking collar to grip the gear shifter if need be.
Nickp - 9/5/18 at 05:07 PM
Just make sure it's a tight fit
Les1 - 10/5/18 at 08:27 AM
I had various bits of hose and tubing
On the avon- passed ok!
Stevie_P - 10/5/18 at 08:30 AM
Thanks for the replies chaps.
I like the bicycle grip idea. I'm sure I can pad it out and make it fit.
