Best finish for gearbox?
ChrisW - 1/12/10 at 12:24 AM
What's the general consensus in terms of finish for a gearbox? It's a cast ali casing, Ford 'BC' FWD box. I've got to strip the box down to fit the slippy diff, so whilst I'm in there I might as well do the bearings, and whilst I have all the parts out to do that I might as well get the thing looking the part.
I've cleaned it up, and obviously it shines nicely in bare ali, but it'll look crap again after a few weeks on the road.
Is it best to powder coat? Paint? Or some other suggestion?
I did think of anodising, but that's a bit over the top I think. I don't want 'bling', just clean and tidy so I'm proud to open the bonnet rather than having a rusty lump of iron in there.
Chris
procomp - 1/12/10 at 12:36 AM
Satin black
stevebubs - 1/12/10 at 12:44 AM
Anodise in Black rather than red/yellow/blue?
Personally, I'd powercoat or similar.
Q: How does clutch fluid react with powdercoat if you get a leak?
Daddylonglegs - 1/12/10 at 06:18 AM
I've gone with Satin Black for the Bellhousing and Silver for the Main case. Looks fine, but ask me again after a few weeks on the road! (If I ever get it on the road that is )
Macbeast - 1/12/10 at 08:32 AM
gearbox paint job
gearbox paint job
Hammerite
scootz - 1/12/10 at 09:30 AM
Originally posted by procomp
Satin black
+1
RazMan - 1/12/10 at 10:01 AM
I would favour powder coat in silver to keep the 'fresh from the factory' look. If you go for a matt (or maybe satin) finish it will attract the dirt like a magnet. Black cars ALWAYS look dirty and a gearbox is a bugger to clean so you want something quite 'slippery' to dirt. Smoothrite is a good alternative.
marc n - 1/12/10 at 10:31 AM
ive just painted my bmw engine and gearbox, did the gearbox 5 wheel silver aerosol and the engine matt black
also painted my hyabusa turbo engine main casings 5 wheel silver with the bolt on housings and casing in gloss black powdercoat and its transformed it no end, will post some pics this evening
ChrisW - 2/12/10 at 07:42 PM
I'm leaning towards powder coat in silver I think. The block is silver hammerite, and I've had the head and inlet manifold done in black powder coat, so should look good.
Thanks guys.
Chris
