I need some help in identifying my front uprights, I have no info on what I have fitted and I am not really in the know about Ford components. Apart
from knowing I have mk2 escort alloy front hubs. I want to identify the Hi Spec brake system I have as I need new pads and discs. I believe its the
Ultralight 4 with 260mm solid disc. I want to know if its the setup for the Serria or Escort.
Front what I can gather I need ford escort mk2 discs that are 260mm x 9mm
I need far better pads and would like some carbon ceramic though cannot find any part numbers relating to the pads. This is the dimentional drawing
for the ones that fit the caliper.
Here's some pics of the front upright assemble any info will be helpful as I cannot seem to get through to Hi Spec.
I have been struggling with brakes on track this year, I have a Furyblade but before changing to vented discs and adding weight I want to try some
decent pads first.
Chris
Your upright is a cut down MK2 Escort strut very common on Sylva designs.
Thanks that's just what I wanted
The discs aren't Escort the shape is wrong the extra holes show they have been re-drilled. Escort MK2 Brake discs are the same as Cortina Mk3-5 ----- just under 9.7" dia and 0.5" thick.
I'll have to check that it's a pain if I have to get discs drilled evertime!
If you are struggling with brake temperature, then you should try ducting some air from the front of the car - closed wheel body styles will suffer
more than a tradition 7 style. If you are struggling with brake feel, then you should put the Hi-Specs in the bin (you maybe should do this anyway),
as they are renowned for poor feel, throwing seals, poor customer service (as you are finding). I've a vague thought about the pads being same
as, or tweaked by hand from, an Elise...
DH2
Originally posted by DH2
If you are struggling with brake temperature, then you should try ducting some air from the front of the car - closed wheel body styles will suffer more than a tradition 7 style. If you are struggling with brake feel, then you should put the Hi-Specs in the bin (you maybe should do this anyway), as they are renowned for poor feel, throwing seals, poor customer service (as you are finding). I've a vague thought about the pads being same as, or tweaked by hand from, an Elise...
DH2
