New Build Question
Jonb_5 - 13/9/17 at 05:42 AM
Hi
I have recently purchased an MX5 as a complete car and am currently stripping it apart and selling most of it.
The plan it to keep thinking gear to put into the locost, however from experience is there anything else I should be looking to keep to go into my build which will save me money in the long run?
The plan was to use engine, gearbox, prop shaft, steering rack and column, gauges, wiring look and potentially seats.
Many Thanks
Jon
snapper - 13/9/17 at 06:05 AM
I'll start the list...
Handbrake and cable/linkages
Fuel tank sender and pump
rash12 - 13/9/17 at 06:44 AM
clocks as they are plug and play and calibrated
Jonb_5 - 13/9/17 at 07:18 AM
Perfect thank you!
I would assume I can buy a fuel tank which would accept the pump/ sender fitting aswell to keep it simple.
Jon
russbost - 13/9/17 at 07:41 AM
Hubs, calipers discs, master cylinders?
Schrodinger - 13/9/17 at 07:46 AM
diff, driveshafts and ecu
SJ - 13/9/17 at 08:04 AM
Steering wheel [for IVA compliance] & wheels / tyres.
Jonb_5 - 13/9/17 at 08:27 AM
I should have probably mentioned i have a ford rear axle so will be using a live setup so no use for the hubs, driveshaft and diff.
Would the steering wheel be ok to use with the fact it is fitted with an airbag?
gremlin1234 - 13/9/17 at 02:48 PM
and the entire wiring loom
ianhurley20 - 13/9/17 at 02:55 PM
and the steering column - ignition switch - key and loom as later ones have a transponder in the key and without the ECU and decoder box it won't go on the standard set up (ie they are a matched set of 3 on the NB and later)
Jonb_5 - 13/9/17 at 04:05 PM
Thank you for all the info.
I shall make sure i keep all these bits, box and label them.
I think I shall call on a couple of friends and we can spend a day stripping the car apart then get rid of the shell to make some room to start the build in the garage.
Jon
nick205 - 13/9/17 at 04:06 PM
interior rear view mirror
wing mirrors
wheel nuts/bolts
wheels and tyres
coolant hoses
coolant radiator (may be too big to fit in a Locost though)
I kept some of these parts from my donor Sierra, but wish I'd kept all of the really.
907 - 13/9/17 at 04:34 PM
The rear view mirror is a good call.
It has a double ball adjustment so fits at almost any angle, up or down to see around a roll bar,
or with a little fabrication upside down.
Generic kit car mirrors are cheap tat and vibrate a lot, and most tin top mirrors are only made for that cars windscreen angle.
Paul G
Ivan - 13/9/17 at 04:48 PM
I know this is slightly off topic but why are you choosing a live rear instead of independent when you have all the right components?
gremlin1234 - 13/9/17 at 04:49 PM
when scrapping the shell ensure you get (or give and keep a copy) receipt for scrap metal (and specifically not car), so you can show it has been responsibly disposed of.
Jonb_5 - 13/9/17 at 08:05 PM
Ok will do, thank you I have a local scrap dealer who will take the steel for me, we deal slot with them through work.
In terms of live or independent rear axle, I was advised by a friend that the live would be easier to do. Would you say this is not the case? I've got a Mark 2 escort rear axle which I have been told is worth a fair bit so could always sell that to raise further funds for the build if people think that is a better way to go.
Jon
ReMan - 13/9/17 at 09:33 PM
put it on sorn and keep the v5 and vin plates even if you lose the shell
ianhurley20 - 13/9/17 at 09:33 PM
Don't know what you are trying to build but a live rear axle!!! You have uprights, diff, driveshafts etc from an MX5 why on earth put the clock back 30 years to an escort live axle. Have a look at the Haynes Roadster book - its a piece of cake independent rear end ( ok its not easy but its no more difficult than trying to locate a few hundred kilos of live axle thats narrow and from a vintage Ford)
PAUL FISHER - 14/9/17 at 02:51 PM
My advice would be to put the running gear into a mk Indy, which are now Mx5 based, it will be more expensive to build but will be worth a lot more when you come to sell it
Jonb_5 - 19/9/17 at 08:50 AM
Out of interest, do people run the mx5 steering rack with power steering in theirs? Or I know you can use it but without the power part of it? Obviously with it being such a light car??
Jon
ianhurley20 - 19/9/17 at 11:57 AM
Most MX5 racks are used without power and to make sure it complies with IVA the rack should be properly 'de-powered'. There are instructions I have read as to how this is done, I think, somewhere on this forum
