Sierra Diff / driveshafts etc. overview required
Terrapin_racing - 29/3/05 at 11:22 AM
Please can someone help? I would like an overview (the compete picture would be excellent) of what fits with what? I have a granada diff (as per sierra) and someone has given me some cosworth driveshafts.
Having been brought up on Mk1/2 escorts I have lost touch and would value an overview on what is compatible with what
* Diffs
* Driveshafts
* Disc based rear uprights
& any pitfalls to what out for!
All help most appreciated and apologies if this is the subject of an older post (just point me to it)
Mr G - 29/3/05 at 12:22 PM
As a general rule all lsd diffs have bolt on driveshafts (i.e cosworth/xr4x4 etc) Choice of ratios - 3.92. 3.62
That leaves the push in spline type driveshafts for the non lsd diffs.
You'll also get 2 diff widths - 7 inch and 7.5
When you start getting into granada components then it can be a bit hit and miss as there are a few odities- some in driveshaft length etc.
As another general rule all sierra disc brake rear ends use the same disc/caliper apart from the 4x4 varients with vented rears which also have larger calipers.
You can get adapter brackets to allow you to mount calipers onto splined push-in driveshaft hubs if you so wish.
Infact you can use good old drums on the bolt on driveshafts that normaly run discs/calipers if you want as well!
Don't take this as 100% definate:
XR4i (1982-1984.5)
Non LSD
7' rear
smaller Sierra stubshafts
drum brakes
3.62:1 ratio
Merkur XR4Ti
Non LSD
7.5' rear
drum brakes
3.64:1 ratio
All XR4x4 V6-powered vehicles
LSD
7' rear
disc brakes
3.62:1 ratio
Late model XR4x4 w/ 2.0 engine
LSD
7' rear
disc brakes
3.92:1 ratio
All Sierra Cosworth RWD
LSD
7.5' rear
LARGE Granada stubshafts
disc brakes
3.64:1 ratio
All Sierra 4WD Cosworth & Escort Cosworth
LSD
7' rear
disc brakes
3:62:1 ratio
Scorpio 24v (Cosworth)
LSD
7.5' rear
disc brakes
3.64:1 ratio
Any RWD Sierra with any 2.0 engine (non-Cosworth)
Non LSD
7' rear
drum brakes (disc optional on last Sierras)
3:92:1 ratio
Clear as mud.........
G
Terrapin_racing - 29/3/05 at 01:54 PM
Thanks for that G
Rob
NS Dev - 29/3/05 at 08:34 PM
Very small addition to the excellent breakdown above, the XR 4x4 had solid rear discs, so the calipers are the same as those on all the other disc rear sierras/granadas.
Liam - 30/3/05 at 01:22 PM
Very nice.
Just in addition...
There are plenty of non-LSD diffs with bolt-on driveshafts.
Liam
kango - 3/1/07 at 05:51 PM
From where to where do you measure to see if you have a 7" or 7.5" diff (on a bolt on drive shaft type)
Liam - 3/1/07 at 06:07 PM
Woah talk about a ye-olde thread!
Measure accross the top mount of the diff(not the mount on the rear case). Just for your information though, the 7 or 7.5" actually refers to crownwheel diameter - as is the case generally when talking about how many inches your diff has! The matching top mount widths are a handy coincidence in the case of sierra diffs.
Liam
P.S. heres some pics for comparison too (the 7" is the little dirty one)... Rescued attachment 7vs7.5diffs2.jpg
Liam - 3/1/07 at 06:08 PM
kango - 3/1/07 at 06:41 PM
My diff has the following plate on it. Rivetted close to the input flange.
98BC-4006-EB
M71 RATIO 4,11
053- 03632
Took a photo, but it is massive and on the smaller file size you can see nothing.
Is this a 7.5" diff?
NS Dev - 4/1/07 at 11:02 AM
no bloomin idea but with 4.11 ratio its a rare one!!!
is that the sierra 1.3 diff ratio?? (yes they made a 1.3 pinto!! )
[Edited on 4/1/07 by NS Dev]
kango - 4/1/07 at 06:26 PM
Did not see the donar, but the salesman told me it came out of a 3.0L Safire.
With this sort of ratio will it be good for a bike engined car or a V8?
seventhheaven - 2/12/10 at 01:25 PM
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at www.super7thheaven.co.uk
Hope that helps - It's a work in progress
