ETB Digidash -flush ?
StuartBJ - 12/9/11 at 07:13 AM
Hey Guys,
Is there an easy way to mount the ETB digidash flush? I have a fiberglass dash and I it looks like I will have to fabricate a pod/bracket to recess it in to and bind that to behind the dash...... unless there is an easier way?
Any ideas or suggestions?
Thanks for the help
pekwah1 - 12/9/11 at 09:26 AM
I'm in the same position with my Acewell.
Think i'm just going to fabricate a pod that i can bond behind the dash.
I think if we protect the digidash properly we can just lay fibreglass strip round the sides and then get a flat piece for the back and bond it all together. Shouldn't be too much of a job hopefully!
dave107 - 12/9/11 at 09:30 AM
Made an Aluminium pod for mine and glassed it in then screwed through into back of digidash.
Have some photos i will try and upload into my photos for you tonight, does look good making that bit of effort to sink it into dash.
Charlie_Zetec - 12/9/11 at 11:32 AM
Could you not not vacuum form the unit, and trim around the form to leave a lip to bond onto the dash with? It wouldn't be utterly flush, but wouldn't protrude nearly as much. Or failing that, make a mould that's slightly deeper than the unit itself to set it flush?
Probably cost you a few beer tokens with a local company....
skippad - 12/9/11 at 11:40 AM
I did similar to last post, made an aluminium backplate, used the template provided for screw holes, made spaces to same depth as Digi dash, bonded them to back of dashboard, carefully cut hole in dash for neat finish.
This way theres no screws showing on front of dash.
dave107 - 13/9/11 at 12:37 PM
Stuart this is what i did for the digidash.
[img]http://i562.photobucket.com/albums/ss67/dave107photo/pic1138.jpg?t=1315848034[/img]
dave107 - 13/9/11 at 12:38 PM
Oh that didn't work i will try again or you can see the pod in my photos.
StuartBJ - 13/9/11 at 09:25 PM
Thanks there, nice tidy work did you bond it in after that? It looks quite robust from this angle.
I spoke to my local vac forming company today and there small jig may damage my digi dash and tpms guage unless I use a plug...... But he did tell me how to do it for free in the oven.
So.... Heat a piece of HIPS in the oven to 100 degrees and then with a hair dryer mould the polymer around the part...... Protect the part with a sacrificial layer (just incase).
I'm going to try a dummy run using the home baking method and if that fails revert to a good old fashion backplate and bond it in with some left over epoxy I have
gingerprince - 13/9/11 at 09:28 PM
I just bent 4 aluminium strips in a flat z shape and screwed these to the back of the digidash and then the dash itself. No pics of the back but on one of these pics you should be able to see the screws that hold it to the dash. It's very secure.
http://www.stuffandting.com/gallery/cars/mycars/mk-indyblade/dash-retrim
McLannahan - 13/9/11 at 09:28 PM
Is it not worth making the former out of a lump of mdf or similar?
dave107 - 15/9/11 at 10:54 AM
Hi Stuart
Underneath the tape there is a flange all the way around which i did glass over.
Dave
Hammy360 - 7/11/11 at 08:07 PM
Mate can you send me a link to your photos please
