I've been tasked with disposing of an old sapphire.
it has no engine or box, but there is a disc braked rear axle and vented front hubs. I'll do more checking later into diff ratios.
The column is intact but we have no keys and the Ign switch has already been removed
All this for about £80-100 but i'm open to offers.
Collect only from OX18.
Cheers Dan.
Have you got much else of the interior or car. You could earn yourself I nice bit of wedge if you break it and stick parts of passion ford and
ebay.
HTH
Just been for another look, It's all old an mouldy.
The car appears to be a 2.0L 4x4, So it's a 3.92 LSD, I might have to adjust the price if thats true, but i can't drag it off the gravel at
the mo, it also means the front hubs have driveshaft holes in them.
ATB Dan.
hi
I might be interested..
at the right price..
cheers Gavin
Do you have the master cylinder? If so, how much and can you get a pic to confirm it's the same as mine.
Dave.
I'll be looking at it again in the morning, Gavin offer would have to be real close It WILL go up if it is an LSD.
ATB Dan.
1st dibs on steering wheel column trims
Are you able to deliver (25 miles to GL55) by any chance? Does it have a prop?
If yes, I'll take it (depending on delivery charge)
Pavs
Gavin has first dibs ont he contents of the car. Once he's done, I'll post up whats left.
Thanks for your interest, Dan
