FS bike TB's + pinto manifold + sensors + air filter
ryanill - 1/10/15 at 04:58 PM
as in title
42 mm throttle bodies with air temp, water temp and throttle position sensors pipercross air filter and all mounted on a manifold to bolt onto a pinto head
collection from Kidderminster or willing to post at buyers expense
£130 ono
[img][/img]
[img][/img]
[img][/img]
maximus1 - 1/10/15 at 09:29 PM
That's a shame I'm looking for none injection. Do you need mega jolt to run on a pinto ?
snapper - 3/10/15 at 07:49 AM
I'll take these if you can give me a bit more info on them
Can't see a fuel pressure regulator?
Did you have them running?
What ECU did you use?
ryanill - 3/10/15 at 08:15 AM
no problems mate
there is no pressure regulator on the fuel rail as it was fed from the bikes self regulating high pressure pump unit sat in the swirl pot witch is pumping at just over 2.5 bar
they were fitted to my pinto for about 5 years and never missed a beat. removed them as iv upgraded to duratec on jenveys
they were ran from a microsquirt V2
hope that helps
snapper - 3/10/15 at 02:30 PM
Ok thanks u2u sent
