Caterham 6 Speed Gearbox Type 9
se7ensport - 15/9/16 at 09:45 PM
Caterham 6 speed gearbox, I purchased unused since it was rebuild a few years ago.
These boxes are rated to a max of 220bhp, and I'm now looking to push on towards 240+ so will be going straight cut (swap possible if you have a heavy duty box with suitable ratios and cash either way depending on spec).
Input shaft has shorten nose so more appropriate for zetec, duratec or vauxhall lump using after market bell-housing than original k-series.
Any inspection welcome, £1600 collection from Bristol definitely preferred unless you can sort a courier and suitable packaging.
20mm bell housing spacer available separately that can be machined to correct thickness depending on bellhousing £25.
Alex
Caterham 6 Speed
Caterham 6 Speed
Caterham 6 Speed Internals
Caterham 6 Speed Nose
Caterham 6 Speed Rebuilt
Barkalarr - 15/9/16 at 10:43 PM
Would you be interested in a 5 speed transX box ?
I might be able to broker a deal as I have a mate with a straight cut box that is moaning it's too noisy...
chris - 15/9/16 at 11:09 PM
I would be interested in the spacer
se7ensport - 15/9/16 at 11:49 PM
Subject to suitable ratios that could be ideal! I'll U2U my number to you.
se7ensport - 15/9/16 at 11:53 PM
Sorry, I should have stated that first refusal goes with the gearbox purchaser / swapper. If they don't need it then its yours.
Alex
se7ensport - 20/9/16 at 08:05 PM
Bump, and open to sensible offers.
se7ensport - 25/9/16 at 11:18 AM
Price drop to £1450.
se7ensport - 13/10/16 at 08:46 PM
On ebay: Caterham 6 Speed Gearbox fits as per Ford Type 9 Gearbox
sam919 - 23/10/16 at 11:00 AM
Hi, did this sell at all? Regards
