FS: Big Old Autumn Clearout
jambojeef - 29/9/16 at 09:41 PM
Lots of kit car related bits - please have a look through - all prices plus post at cost or collect from Hexham, Northumberland or Bedford
ST170 6 Speed Gearbox £30
'Trailer" Style lights for westfield etc £10 for the pair
LED rear lights - defo not IVA proof but small and compact - never used - brand new in the box £8 for the pair
Sintered race pedals - make your own pedal box by bolting these to the end of 1" box section - worked a treat for my 1st locost £5
Old (but working) facet fuel pump from 1999 Caterham running 1.6 8v VX engine £5
Focus ST170 Pedal box with clutch master cylinder £10
20t Mild Steel trigger wheel - centre bore approx 40mm, OD 65mm - good for speedo trigger £5
1.8 CVH Engine - condition unknown! everything you can see in the pic - fuel pump, carb, water rail, head + block etc £50
Cone breather / carb filter - 60mm inlet I think, 80mm total height £3
Battered and bruised SEIW Westfield wide front arches - fit comfortably over 195mm tyres - would probs accommodate wider £25 for the pair
Rear Light Set - Stop/Tail x 2, Indicator x 2, Round Fog x 1 (cracked surround - would repair) inc all bulbs £20
Brake fluid reservoir (ex BMW e39) - 3 outlets with float switch for low brake fluid warning £8
Twin H4 Hi-Lo 4500k HID kit - was on my VFR and very very bright - 1 new bulb needed £15
MGF Heater Box with fan, wiring and matrix - could be modified to suit a 7 if you're keen! £10
Ok - more to come but I need a break for 2 mins!
[Edited on 29/9/16 by jambojeef]
jambojeef - 29/9/16 at 09:50 PM
Apologies for the sizing - you'd think id have learnt by now
Barkalarr - 30/9/16 at 06:38 AM
Can I have the Landrover style indicators and stop lights please. I only want the round lights clear and red please.
Just 4 lights - is this possible ?
jambojeef - 30/9/16 at 06:52 AM
LED lights sold
jambojeef - 30/9/16 at 06:56 AM
Hi barkalarr, I'd like to sell the LR style lights all in one go really
kingster996 - 30/9/16 at 08:32 AM
Yeah, or Chris W could just add ".threadtxt img {max-width:1000px}" to the site's CSS and it will never show huge images full size again.
Interested in HID's - would they fit inside dominator-style 4" headlights do you think?
I'm (presumably) close to you so can maybe have a look?
jambojeef - 30/9/16 at 09:06 AM
The actual bulbs are fairly small and the ballasts are quite slim too so you e a fighting chance!
I'm in Hexham and you're welcome this weekend if you fancy - u2u me
benedwards64 - 30/9/16 at 10:43 AM
PM'd re: arches
jambojeef - 30/9/16 at 11:14 AM
Arches sold - thanks Ben
CosKev3 - 30/9/16 at 01:00 PM
I looked into this a while ago,the big black plastic piece on the rear of the bulb won't fit in dominators from the measurements I found
kingster996 - 30/9/16 at 10:13 PM
Thanks. Saves a trip to the darkest depths of Northumbria for me then :-)
Although tbh I'm there most weekends for a blat!
[Edited on 30/9/16 by kingster996]
coozer - 30/9/16 at 10:41 PM
Hi Geoff, I'll take the gearbox off ya! Haven't got any st wiring have you??
kingster996 - 30/9/16 at 10:53 PM
What you after Steve? I have engine harness.
Edit: sorry for hijack obviously first reply goes to Geoff
coozer - 1/10/16 at 02:12 AM
The ecu to engine. Got that bit??
jambojeef - 1/10/16 at 08:39 AM
Gearbox sold to you sir and I've got a huge box of wiring you can have if you like! Most of it has been a bit cut / shut but I guess some plugs and things are there?
fregis - 1/10/16 at 03:06 PM
i am interest in steering rack? do you sell it?
jambojeef - 1/10/16 at 05:19 PM
Hiya,
Is it st170 steering rack you need?
Or the MGF one? I have both I think - and the EPAS system and loom for the MGF
fregis - 1/10/16 at 06:52 PM
mate building one seat race car, maybe fit for him.
this one
[Edited on 1/10/16 by fregis]
Barkalarr - 2/10/16 at 07:32 AM
Ok pal, i'all take them all.
Will PM you my email as I don't get notifications from this site when you answer me.
