Hi all,
Bought the below sheet metal folder in anticipation of needing it for a project...
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F173113581497
It is advertised as a box pan folder but I was just going to use a a normal folder. Now I will need to make a fair few boxes and to do these you would
need to cut the clamping bar into segments and it’s not something I have the kit to do properly so I have bought a fingered one instead. You can just
use it as a folder (it’s pretty beefy and can handle 2mm+ steel).
It is fairly heavy so will need collecting from redditch B98.
£60 for lcb members
interested. Will message you
Back up for sale due to timewaster
