I have just upgraded to a covered trailer so I now need to sell on my old trailer. This trailer was originally built by Mark fisher and so was
designed for the Fury but I have used it over the last couple of years for my Striker and it works just fine
Good points..Tows really well (I now have a Brian James and that tows no better (or worse)) and has nearly new proper trailer tyres on it. So old it
has no rate plate but its safe for a car like the Fury (tyres are good for 750Kg each). In the last two years I have replaced the jockey wheel, added
rear stands, new light board (and wiring) and new mudguards with rear reflectors plus the brakes and bearings have been serviced. It will come with
the hitch lock and padlock I have used with it. I have covered about 1,600 miles with it and never had a problem.
Bad points..it looks old and the handbrake isn't great. The reverse lockout has never worked but I have always turned it around by hand, being
relatively light this has never been an issue. Spare wheel only has a normal car tyre fitted, good enough for an emergency. It has a front winch but I
never used it and if I did I would replace the strap as that looks very old now.
During my ownership it has been kept under cover until this weekend when I moved it out the way for the new trailer. Price is £475 and it It is
located just outside Tunbridge Wells. I could possibly deliver within a 30 or 40 mile radius as £0.50 per mile (each way) and with payment made
up-front however I am busy so finding a mutually suitable day for delivery could be a challenge but ask if that is of interest.
A few pictures are bellow, if you want any more just ask.
looks really good solid trailer - do you know what it weighs?
ta
H
ta
H
Hi what is the exact width (widest point, outside of wheel arch) and length please?
