Sale of unstarted project
scutter - 19/3/19 at 05:54 PM
Due to a drastic change in circumstances. my Alfa V6 Haynes roadster if up for sale.
I'm currently having trouble uploading photos, but if there's anything you think you may need just shout and see if I've got it.
I'm very willing to break the car, which can be found in my photo archive under MD7.
Full Haynes Roadster chassis,
Front and rear suspension including rose jointed rear lower wishbones to adjust toe.
Protech alloy dampers.
Full loom.
Digidash II system.
Full car set of lights.
Wilwood midilite calipers, Cosworth 285 x-drilled and grooved discs, mintex 1144 pads
Cobra 7 seats X2
Unique bits,
Alfa Romeo 3 litre Busso engine, rebuilt, high compression heads. Haynes built Exhaust with 7"silencers and switchable race cats, straight pipes.
Cosworth T5 gearbox with modified bellhousing to bolt direct to the Busso engine/.
The only thing sold so far is the Megasquirt and O2 sensor.
Kind Regards Dan.
wowblaauw - 19/3/19 at 08:53 PM
Hi, I’m interested in your Willwood Calipers, discs and pads. PM sent
martin62 - 20/3/19 at 07:51 AM
I am interested in the Protech Shocks PM sent.
Mark100 - 26/3/19 at 10:19 AM
price for seats thanks
scutter - 26/3/19 at 11:41 AM
£100 collect from nr18
Dan.
Mr Whippy - 26/3/19 at 12:38 PM
drastic change in circumstances? sounds interesting...
PaulYDP - 26/3/19 at 01:29 PM
Could you U2U me a price for the Digidash?
Paul
scutter - 26/3/19 at 02:43 PM
Divorce will do that. 😊
big_wasa - 26/3/19 at 04:50 PM
Is the dash the etb digidash lite 2 ?
If so I am also interested in deetails.
scutter - 26/3/19 at 05:10 PM
Sorry folks Digidash sold yesterday and in the post.
Dan
scutter - 27/3/19 at 01:56 PM
Hopefully these photos will upload after a morning on Imgur.
Chassis, £250. All wishbones, hubs, steering column and rack, lowered floors, CDS rollbar, fuel tank a few misc. panels. No Dampers as sold.
Sierra 3.64 LSD with driveshafts £250
Dezent 15" alloys new Toyo tyres £150
Wilwood Midilite 284mm sierra Front set up inc. 1144 pads £300
Sierra rear calipers and discs £50
Pedal box, balance bar, 3 master cylinders, 1 IVA reservoir, 3 single reservoir cable bias adjuster. £150
Oil cooling set up,take off plate, remote filter housing, thermostat valve and cooler. £100
Westfield screen mounts £25
Alloys sheets, 1.5mx3mx1.2mm and 2 4'x12'x16 gauge £100 Collect only
Seats Cobra roadster 7s, no harness holes, 2 tear in a seat £100
Bodywork set, Will need painting, high level nosecone£200
Electric set up complete, No steering column or wheel. MX5 switch gear £400
Fire extinguisher exhausts 7" diameter. need centre perforated tube, mounts, come with 100cpi cats. fist sold will get exhaust wadding £30 each
AL-KO 1.3ton trailer axle. £75
All items in NR18, large/heavy items are collect. Thanks for looking. Dan
[Edited on 27/3/19 by scutter]
jps - 27/3/19 at 09:07 PM
You're in Wymondham, Norfolk - or thereabouts then?
I could be interested in the wheels/tyres - how long have the tyres been on them, what width are they, what PCD are they, and what offset?
[Edited on 27/3/19 by jps]
scutter - 27/3/19 at 11:15 PM
Suton just south of Wymondham, I'll have to look at them on sat when I'm back on the farm.
Dan.
big_wasa - 28/3/19 at 07:06 PM
Have the front brake sold Dan ?
scutter - 28/3/19 at 09:07 PM
Front brakes still available buddy. Dan
scutter - 2/4/19 at 08:04 PM
My apologies to everyone for the delay in messaging them. Now all answered.
I'm away from the farm until the week after easter now, starting the 23rd April. So any purchases will be posted after that.
Regards Dan
scutter - 25/4/19 at 05:28 PM
Final Bump before being listed on Ebay.
Dan.
HowardB - 25/4/19 at 07:18 PM
what's left?
CeeBee - 7/5/19 at 11:34 AM
Hi There Scutter,
I'd be very interested in the Westfield Windscreen pillars if still available?
Regards
Chris
wrayvon - 7/5/19 at 02:49 PM
Are the sierra rear calipers still available by any chance?
And the red top battery...?
[Edited on 7/5/19 by wrayvon]
1960dave - 8/5/19 at 07:16 PM
Has the exhaust sold yet
scutter - 9/5/19 at 11:50 AM
Sorry for the delay, laptop issues and I can't get on with the site on my phone.
Definitely sold are;
Dash.
Dampers.
Front and rear brakes.
Battery.
Provisionally sold are;
Seats.
One exhaust
Screen mounts.
Haven't had time to list on Ebay due to shift work, so everything else is still available.
Regards Dan
wowblaauw - 9/5/19 at 02:21 PM
Hi Dean,
You have listed the following:
Can I buy the thermostat on its own?
Craig
scutter - 9/5/19 at 02:46 PM
Yes buddy, £50 posted.
Dan.
wowblaauw - 9/5/19 at 03:26 PM
U2 sent pal
BenBrooks - 9/5/19 at 04:49 PM
u2u sent
1960dave - 9/5/19 at 06:35 PM
Would you post one of the exhausts?
nye - 9/5/19 at 07:43 PM
Are driveshafts modified to fit? If so would you post?
scutter - 10/5/19 at 11:19 AM
u2u's replied to. Drive shafts aren't modified as wishbones made wider.
Dan.
scutter - 10/5/19 at 11:34 AM
More bits.
Meagsquirt V2, set up for V6 with wasted spark, knock input and has a USB input, comes with wideband sensor/guage and knock conditioner. £400
Alfa Romeo V6 engine, balanced, heads skimmed to 11 to 1 comp ratio. comes with downpipes, desno alt. requires water pipes to T stat, clearances set and rocker covers fitted. has flywheel to take direct attached gearbox not transaxle. £500
Borg Warner T5 gearbox, modded bellhousing for Alfa Engine which can be unbolted for fitment of Ford bellhousing. Ratios looked up, it came from a 2wd sierra cosworth. £750
Regards Dan.
[Edited on 10/5/19 by scutter]
CeeBee - 11/5/19 at 08:35 AM
Hi Dan,
Please could I buy the windscreen pillars.
How do you want payment?
Regards
Chris
scutter - 11/5/19 at 08:57 AM
Chris, please check your u2u messages.
Dan.
scutter - 19/5/19 at 10:01 AM
Now on the EBay
Dan.
wowblaauw - 19/5/19 at 10:24 AM
Dan, just to let you know, I received the oil thermostat, thank you very much,
very happy.
Craig
scutter - 19/5/19 at 10:28 AM
Not received fella.
Dan.
scutter - 19/5/19 at 10:33 AM
You're welcome fella.
Dan
