Lots of zx12r MK and BEC parts 3:38 lsd etc
flanders - 3/9/19 at 12:09 PM
Everything located in the UK
I can possibly ship worldwide.
Please PM me if you’re interested.
17k A1 engine excellent compression on all cylinders - £1000
Hays billet clutch basket - SOLD
Stator and cover-£60
Clutch cover - £100
Clutch hub (oil mod done) - £40
Trumpets - £30
clutch plates/steels/springs/pullers - £ ask
Starter - £75
Coils - £80
Regulator - £30
TPS -£65
OEM exhaust can - £65
Used HJTX14H lithium battery - £60
Brand new HJTX20CH lithium battery - £100
Brand new Dynojet flat shifter pull type sensor (PC5) - £120
Reverie airbox with filter and 5-4” reducer (fits any PX600 filter plate) - £250
Custom built 3:38 ford LSD (100mm lobro) - £450
Hispec cortina upright ‘short’ steering arms (quickens the rack) - SOLD
MK wishbones - £30ea
150 lb 8” springs (a bit scabby) - £25
225 lb 9” springs (v good cond ) £50
Westfield 300mm leather steering wheel - £80
Stack lambda gauge and sensor (wires need re-joining) - £250
Stack fuel pressure gauge and sensor (new) - £150
Sytec Fuel pressure regulator (new) - SOLD
100mm Lobro shafts - £50
Sierra disc brake hubs - £50
Sierra stub axle and new nut - £25
Diff pinion flange - £25
[Edited on 4/9/19 by flanders]
flanders - 19/9/19 at 10:47 AM
the following parts are sold-
Clutch cover
Reverie airbox
Stack lambda
Lobro shafts
steering arms
maurof74 - 8/10/19 at 07:59 AM
Hello,
I'm interested in the HJTX20CH litium battery.
From the website I see it has 360 Amps CCA but I'm not sure about capacity because in the website I read PBEQ 14 (I assume Ah), but in the battery picture it is stamped 72 Wh which corresponds to 6Ah (= 72/12).
Do you know that info ?
Thank you
Mauro
Hello,
Thank you
Mauro
maurof74 - 9/10/19 at 03:16 AM
...ok I just learned that Pbeq is typically 2-3 times the actual capacity of the Li batteries to compare with the Lead ones, which can be discharged 30% only before voltage drops down...
flanders - 9/10/19 at 06:49 AM
Hi mate. Sorry I didn’t get back to you sooner.
I’m not totally clued up on the batteries but you can’t directly compare lead acid with Lithium.
If memory serves...The CCA of this battery can start up to 1800 cc and the smaller one can start up to 1400cc
They’re not designed to a have a prolonged drain on them like lead acid can
flanders - 9/10/19 at 07:53 AM
the following items have been sold -
Stator and cover
Clutch cover
Clutch hub
Reverie airbox
Diff
Stack lambda gauge
100mm Lobro shafts
steering arms
maurof74 - 9/10/19 at 11:18 PM
U2U sent about the battery HJTX20CH
