zetec type 9 bearing.
David_17 - 2/6/12 at 03:33 PM
I know its a long shot, but don't suppose anyone based in the north east has a bearing that adapts the zetec crank to mate up to a type 9 input shaft?
Im half way through swapping my blown up engine, havent got a bearing, can't get the old one out and everywheres's shut for 4 days
Please... Someone help!!!
Chippy - 2/6/12 at 03:54 PM
Get a bolt thats a tight fit in the bearing, pack the bearing with grease put the bolt in and give a good thump with a hammer, should drive the bearing out. HTH Ray
David_17 - 2/6/12 at 04:04 PM
Will try that after tea. Been trying hooking things behind it for hours!.
Thanks for the tip
David_17 - 2/6/12 at 08:36 PM
No joy, tried everything and it won't budge. The full thing is ripped to bits and the outer casing is still solid in the engine. Looks like axle stands until Wednesday.
Chippy - 2/6/12 at 09:45 PM
Pity that usually works a treat. Cheers Ray
hootsno1 - 2/6/12 at 09:51 PM
Add some heat to the outer case the tap it out
David_17 - 2/6/12 at 09:57 PM
No need now cos the bearing's no use and neither is the engine its stuck in.
