Wanted: Tillett B6 or equivaent
Trigger1 - 9/8/18 at 06:25 PM
I'm looking for a Tillett B6 or equivalent seat if anyone has or knows of one for sale?
matt5964 - 9/8/18 at 08:04 PM
On the bay
263861035653
123289207122
123261306030
323357735883
253759755710
263822617807
323375220796
323385496919
142895182188
Trigger1 - 10/8/18 at 07:18 PM
Originally posted by matt5964
On the bay
263861035653
123289207122
123261306030
323357735883
253759755710
263822617807
323375220796
323385496919
142895182188
Thanks Matt, unfortunately it needs to have the bulge in the bottom and other than the first one (which would have been perfect but has been removed!!) and the second which is too expensive for me (£500) the others are no good
[Edited on 10/8/18 by Trigger1]
matt5964 - 10/8/18 at 08:34 PM
No worry’s
Why does it need to have the bulge in the bottom?
Trigger1 - 10/8/18 at 09:16 PM
No worry’s
Because I am on the tall side and I need to be as low as possible.
matt5964 - 10/8/18 at 10:09 PM
Ah ok, with the correct brackets most of the ones I posted will fit with the seat base on your floor
The below has a similar bulge and cheap
323385496919
I doubt you’ll get a Tillett for much less than £450-500, worth every penny as they are so much stronger and finished better than the rest
Trigger1 - 12/8/18 at 06:38 PM
323385496919
Thanks matt They are about £550 new now so hoping I can get one a bit cheaper.
matt5964 - 12/8/18 at 06:44 PM
No worry’s
550 new is a good price thought they were just under 600 when I was looking, wend for b5’s in the end
Trigger1 - 15/8/18 at 05:11 PM
No worry’s
I had B5's before but prefer the higher sides of the B6 for track use.
matt5964 - 16/8/18 at 08:50 PM
Just see thease two pop up for sale, made by Tillett virtually same as B6
142904653656
142904645796
Trigger1 - 17/8/18 at 07:41 PM
142904653656
142904645796
Good find, thank you
Trigger1 - 28/8/18 at 08:44 PM
Still looking
GavMax - 2/9/18 at 08:08 AM
Hi
I have a Tillett seat that was built for a xanthos that I no longer need. It has the bulging bottom but it also has heated pads to keep you warm.
If you look on my photo archive, you will see some photos and dims.
It cost me £200 and I would like my money back from it is that is possible.
Let me know if it might work for you - feel free to pm me
Gavin
Trigger1 - 23/9/18 at 06:55 PM
Still looking
