hi im trying to get my sprocket set up correct has anyone got a 40 41 42 tooth sprocket for a open chain diff even a worn one just so i can get the
right size before i buy new and its the wrong size its for my r1 mini van
[Edited on 21/7/19 by doddy]
Originally posted by doddy
hi im trying to get my sprocket set up correct has anyone got a 40 41 42 tooth sprocket for a open chain diff even a worn one just so i can get the right size before i buy new and its the wrong size its for my r1 mini van
i have a 530 chain on a Quaife ATB QDF14K chain lsd but i only have a 46 and 47 tooth which are way to far off
Just checked, sorry looks like the 42 tooth I had got binned, only thing I have is a 37 tooth which is 200mm across the diameter, point to point of
the teeth. That was for a ZX10 chain which I seem to remember is also 530.
I normally use 46 tooth.
Just one additional thing to be careful of, never use a sprocket which has an exact multiple of the front sprocket size, eg 14 to 42, (3 : 1 gearing)
it will give horrible resonance & rumble as you always get the same teeth coinciding with the same teeth on each sprocket
Try Westgarage Engineering Services:
https://chaindrivediff.co.uk & http://www.westgarage.co.uk/index.html & http://www.westgarage.co.uk/calculators/calculators.html
Mike
