Cheap TIG?
Slimy38 - 15/4/18 at 12:15 PM
Has anyone used one of the cheap options for TIG? I'm referring to the TIG/MMA such as the Clarke units;
https://www.machinemart.co.uk/p/clarke-at162-arc-tigmma-inverter-welder/
together with a TIG setup such as this;
https://www.machinemart.co.uk/p/clarke-tig-welding-torch-assembly-for-at161-in/
The reason I ask is that I got a VAT free day through from Machinemart, and I'm tempted to have a go at TIG. I don't really want to spend loads on a good TIG setup, but then again I don't want to spend money on something that is unusable.
theconrodkid - 15/4/18 at 02:50 PM
I have a similar one, it works well on steel only obviously, the killer is the gas tho, it aint cheap and you do use
a lot of it
v8kid - 15/4/18 at 02:57 PM
I bought this "TIG WELDER 200 AMP PULSE WSM WELDER 2 YEAR UK WARRANTY UK SELLER" off ebay just cos it looked identical to my bro in laws which has given faultless service for 4 years. As a bonus he paid 250 for it and mine came in at 180.
Pumps out 200A no problem. Well when I say no problem the torch gets bloody hot I guess you need water cooled torches to weld with 200A continuous. Usually I'm around 80 -100A and the welder supplies this for as long as I want to weld.
Quality is good. The arc strikes easily and the HF turns off by itself when arc established. Arc is stable and does not wander about and the welds look pretty cos its easy to make even steps.
Bro in law uses his as a portable stick welder on the boat and it gets some abuse running flat out but never falters.
Another TOP TIP is get 2 dioptre lenses for your welding helmet they are the best thing since sliced bread. No need to take your glasses off everything is in focus and magnified making placing the welding rod easy and contributing to those pretty welds.
I used to knock cheap Chinese stuff buy the quality is increasing in later years and I would have no hesitation in taking a punt.
Cheers!
Just read Conrodkids comments the answer is Adams gas suppliers.
[Edited on 15-4-18 by v8kid]
Slimy38 - 15/4/18 at 03:33 PM
a lot of it
Why only steel? Can't it do aluminium?
MikeRJ - 15/4/18 at 05:58 PM
a lot of it
No, you need an AC/DC TIG if you want to weld aluminium and steel. Aluminium doesn't weld at all well with DC which is what these cheap inverters produce.
DanP - 15/4/18 at 07:22 PM
I had exactly the kit you linked to (older version though) as my first tig set (and first welder) it got me started and I did manage to make a pair of SS headers for a V8 (see my archive) with it but with scratch start and no foot pedal (plus being pretty new) I had to do A LOT of grinding.
If you look on youtube for "welding tips and tricks" he does show how to and where you would use scratch start.
I upgraded to a AC/DC set with a foot pedal from R-Tech and I would never go back, it is more expensive but it is significantly better. I think they do some cheaper DC only machines too.
If it were me I would save up and get a proper HF start with a foot-pedal.
This: https://www.r-techwelding.co.uk/tig-welder-240v-dc-160amp/ would not disappoint.
Dan
JonBowden - 16/4/18 at 09:56 AM
I went for the R-tech too,
I find it to be excellent but I am tempted by the cheap Chinese AC/DC TIGs as I'd really like to be able to weld aluminium.
I looked into gas options fairly carefully.
For me to get biggish rent free cylinders, I'd have to drive a significant distance but I have a BOC agent around the corner from me.
I have rented a Size Y cylinder for I think 75/year and 50 per refill - these are big heavy cylinders.
The break even point for BOC vs the best value rent free cylinders was about two BOC refills per year.
[Edited on 16/4/18 by JonBowden]
prawnabie - 16/4/18 at 03:57 PM
Ive got the above AD/DC rtech one if you want to come round and have a look I'm not far from you
[Edited on 16/4/18 by prawnabie]
