Fitting Mac#1 mirrors
Paul W - 23/9/10 at 12:13 PM
I have a set of side mirrors from Mac#1.
they have a rubber shroud around the arm and a shaped plate but no fitting instructions.
Ive tried different ways but nowt looks right.
any ideas??
cheers Paul
tried to attach a photo but cant find how to
[Edited on 23/9/10 by Paul W]
bi22le - 23/9/10 at 12:30 PM
Alot of the MAC1 I have seen have a full cage and they are fitted to that. Are you fitting it to a full cage?
They drill a hole in the cage and tap a thread.
HTH
Paul W - 23/9/10 at 12:36 PM
putting them on a robin hood zero scuttle
bigrich - 23/9/10 at 01:17 PM
newark2005
newark2005
you may need to have the rear of the mount slightly higher than the front edge to make sure you can see over the rear wheel arches
sory if the lady in the bikini spoils the view of the mirror
l0rd - 23/9/10 at 03:59 PM
yes, she does indeed.
She's ugly
karlak - 23/9/10 at 04:16 PM
Originally posted by bigrich
newark2005
newark2005
What Mirrors ???
shortie - 23/9/10 at 04:28 PM
does this pic help?
SVAReady8
SVAReady8
[Edited on 23/9/10 by shortie]
Can't remember 100% but don't you just use the plate as a template, drill the holes, then fit the mirror and put the plate on the inside and tightten the bolts against it to hold it securely?
Rich.
bi22le - 23/9/10 at 09:33 PM
Im sorry I have given duff info!
Looking at the pics has reminded me that my car had Racetech mirrors.
Soz for giving crap info!!
Paul W - 23/9/10 at 11:26 PM
aahhh
I was using the plate to support the rubber where the rubber meets the scuttle.
cheers for info
