Bonnet catches
chris_smith - 18/1/17 at 09:30 PM
Has anyone ever us d this type of fastener for bonnets? If so what are the thoughts of those that have?
YouTube link
Link
[Edited on 18/1/17 by chris_smith]
SCAR - 18/1/17 at 09:44 PM
Like the look of those. Thinking of using them but thought they were a bit expensive for what they are.
chris_smith - 18/1/17 at 09:51 PM
Yeah but demon thieves are always a little inflated, I'm searching around now I like them a lot different from the usual latches
daniel mason - 18/1/17 at 11:54 PM
I used black ones on my old force hillclimber! They were great
slingshot2000 - 19/1/17 at 08:49 AM
Please let us all know if you find a more reasonable priced supplier. I think they look very useful.
Thanks.
Jon
axle - 19/1/17 at 10:47 AM
my concern would be when the sping is worn it might give up with no worning, good for a flat panel not a bonnent on 7 .
coyoteboy - 19/1/17 at 12:10 PM
Springs don't generally wear? In a lightly loaded spring in low temperature the creep should be so minimal it's not even worth considering.
loggyboy - 19/1/17 at 12:35 PM
I considered them over aerocatches but didn't like the lack of lockability.
mcerd1 - 19/1/17 at 04:26 PM
that and the fact that the load on them is pulling the same way that they open
but with the aerocatch the pin has to move at 90° to the load to release it and the mechanism doesn't take any of the load being applied to the pin.
while I'm sure both are fine normally - a worn areocatch will rattle, but a worn one of those type might let go of the ball on teh end of the pin....
[Edited on 19/1/2017 by mcerd1]
chris_smith - 19/1/17 at 04:54 PM
They also do lockable ones -
Link to lockable ones
There isn't an official U.K. Distributor , a French company looks after the whole of Europe (RRS Direct) there are a number on eBay, I'm still researching will keep you all updated with anything I find
loggyboy - 19/1/17 at 05:25 PM
Bargain!!
daniel mason - 19/1/17 at 07:13 PM
No amount of load would release the non lockable.
You need to fully de-press the centre section to release them.they are good
chris_smith - 19/1/17 at 10:29 PM
Ok so after numerous hours trawling the web, the best I can come up with are these -
Link to BYC
These are £50 but comes as a pair and are twice the dia of the mini quik latch
I also came across these -
eBay link
But are from china and I guess you get what you pay for
Toys2 - 20/1/17 at 02:12 AM
ta daah!
UNIVERSAL EPMAN QUICK MINI LATCH FASTENER PAIR HOOD PIN - AVAILABLE IN 4 COLORS
and thanks, I may steal your idea
