Dent puller suggestions
number-1 - 24/8/19 at 03:56 PM
Can anyone suggest a cheap dent puller for a few small dents on a car? Id rather not weld stuff to the body.....as i cant weld
ive seen one that is glued on and then a puller is attached.
Cheers folks
Mr Whippy - 25/8/19 at 04:27 PM
Might be worth speaking to a specialist in paintless dent removal, I had a ding in the centre of the door and it was completely removed for £80, complete bargain imo
perksy - 25/8/19 at 08:01 PM
As above its worth speaking to a pro
I use a local chap who's brilliant with PDR and he also does glue-pull which is what you are talking about
(The paint needs to be sound before using glue-pull otherwise it can go pearshaped quickly)
There's a few kits on ebay and Amazon if you fancy having a go though...
