Braided Fuel Line Query
johnny chimpo - 18/10/15 at 08:58 PM
Hi All, another Sunday night silly question from me i'm afraid.
As per my other thread I am planning on running a swirl pot setup on my R1 powered MNR. All of the connections in my fuel system apart from the engine and standard bosch pump are -6 fittings. I've just ordered a load of -6 Teflon stainless steel fuel hose for the fuel system.
For the parts of the system with the -6 fittings, this will be straight forward, but how do I secure the fuel hose over the barbed fittings on the standard bosch fuel pump (8mm & 12mm) - will normal hose clamps work, or are there different hose clamps that should be used with this type of fuel hose?
G
big-vee-twin - 18/10/15 at 09:53 PM
You can get a finisher which is basically a jubilee clip with an anodized cover to match the JIC fittings.
Badger_McLetcher - 19/10/15 at 06:04 AM
I think these are the buggers you need:
�� MIKALOR DOUBLE EAR HOSE CLIP O CLAMP - MULTIPLE PACK SIZES - CHEAPEST ��
ReMan - 19/10/15 at 07:31 AM
These?
4pcs -8 AN 8 AN8 STAINLESS STEEL / NYLON BRAIDED HOSE CLAMP COVER FINISHER BLUE
These?
