Do any electronics buffs on the forum know if I can buy a voltage regulator as a module or kit. The input voltage would be 12-14v DC, I need a very stable 5v output and the unit would be required to handle up to 1Amp or close. Thanks.
Maplins is the place. But, in Malta?
You basically need a 7805 regulator. Depending on the environment you might need to fit some capacitors either side of the regulator. You'll need a hefty heatsink as you'll be turning approx 9W into heat......
You could try something like this from Ebay if you don't fancy making one on some stripboard....
ebay linky
LM2940CT was suggested to me as a better choice for automotive than the older 7805 series regulators. Harder to get, but copes better with the rather
aggressive electrical environment. As BenB says for full 1A operator you need a good heatsink.
Can be got from Farnell (and probably RS) datasheet attached to this page.
http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=9490191
Wow thanks for the quick replies guys.
A switching regulator gives much better efficiency, it won't get very warm at all since the excess voltage is not converted into heat.
Something like
this would be ideal if you want a module ready to wire up.
