fly by wire
t11 - 20/4/13 at 05:16 AM
Morning all..has anyone out there retro fitted a fly by wire system to throttle bodies ? I have a set of suzuki haybusa throttle bidies fitted to my toyota 3sge engine and wondered if this is possible and what parts and from which car to use......many thanks Gordon
liam.mccaffrey - 20/4/13 at 07:52 AM
Can I ask why you would want to do that?
adithorp - 20/4/13 at 08:06 AM
My thoughts, exactly. Stick with KISS.
umgrybab - 20/4/13 at 10:51 AM
I don't even know if any major manufacturers use fly by wire on their petrol engines. It is used on diesel engines because of emissions regulations and injection timing under load, however, I think that even the mainstream manufacturers use a cable for petrol engines because its easier/cheaper/not a huge benefit. They all have a TPS for mapping but I can't see why you would want a fly by wire system. Only time I can think it may be useful is to blip the throttle for shifting a sequential box but this is usually done with spark kill on the ECU anyway.
MikeRJ - 20/4/13 at 10:59 AM
Most of them do, even small shopping cars have motorised throttles these days. It makes traction and stability control and cruise control much easier to implement for starters, and they play all sorts of tricks to smooth out throttle response etc.
[Edited on 20/4/13 by MikeRJ]
matt_gsxr - 20/4/13 at 01:27 PM
Don't the Suzuki throttle bodies already have a second throttle butterfly that is electronically controlled? Maybe you have removed them?
Not sure what signals it needs, but you might find some information here. http://www.msextra.com/forums/viewtopic.php?f=131&t=33297
I have considered adding a second electronic throttle to the inlet of my turbo, not because boost lag is a problem (it doesn't seem to be) but because F1 Renault did it way back and it might be fun, I haven't got around to it. A Golf GTI unit looked about the right size for the job when I looked.
I believe that megasquirt can provide a PWM output for this type of purpose, but not sure whether any code supports this functionality.
Slimy38 - 20/4/13 at 02:11 PM
My 2001 Toledo has it... but I have no idea why. The 2000 version of the same car uses a traditional cable throttle. It still has all the other tricks like cruise control etc.
My only experience of it (apart from actually making the car go!) is having to get it calibrated whenever I do any work on the throttle body. It needs a command sent through OBDII to set it correctly. I'd have much preferred the old cable throttle with a nice easy screw stop.
theprisioner - 20/4/13 at 02:29 PM
Automatic parking systems need it.
t11 - 20/4/13 at 04:55 PM
ok so its like this the car is rear engined with a home make pedal linkage and the cable is 7ft long its not very smooth and starting from rest is a pain so I thought fly by wire might work........
coyoteboy - 20/4/13 at 05:40 PM
I like your thinking and I might consider implementing it myself but I'd want to know damn well that the thing is failsafe. AFAIK there's no easy way of implementing it, certainly not reliably on throttle bodies. You'd have to do a proper engineering job on it for it to operate satisfactorily, but it does offer some nice benefits that the KISS folk might appreciate if it were easily achieved.
dave_424 - 20/4/13 at 06:28 PM
What accelerator cable do you have? I bought one with teflon liner and all the fancy coatings etc, its smooth as butter. Also found it helpful to add an extra strong spring onto the throttle bodies for a snappier return.
l0rd - 20/4/13 at 07:57 PM
i believe there is a youtube video of a renault clio which has been converted to itbs and they kept the fly by wire throtle mechanism to control the butterfly
