Testing Fuel Gauge with Sender - Advice Wtd.
Dick Axtell - 28/6/18 at 04:40 PM
I have a new fuel gauge which I hope will match up with the recently obtained sender. Both are rated at 270 ohms/ 18 ohms. The wiring connections are shown below.
Fuel_Gauge_Wiring
Fuel_Gauge_Wiring
I plan to test gauge and sender off the vehicle, using this wiring set up. Should I also connect a resistance load in parallel with gauge and sender, to prevent possible excessive current loading?
I welcome your constructive advice.
Smoking Frog - 28/6/18 at 05:01 PM
In my opinion no, there will be no current between sender and gauge, only a resistance value between sender and earth.
theconrodkid - 28/6/18 at 06:15 PM
some gauges run off 9 volts via a stabaliser, just to prevent the gauge going up n down with battery voltage, should be written on the units or in the paperwork if you have any, worth a punt round on-line.
gremlin1234 - 28/6/18 at 07:33 PM
the old style gauges ran on a nominal 9 or 10V system. but that was a by-metallic strip, switch open and closed. (quite slowly, but a early form of 'pulse width modulation' for voltage control.)
I would recommend a modern 9V (7809) or 10V regulator in the circuit
actually for testing, just use a pp3 9v battery
wylliezx9r - 29/6/18 at 07:05 AM
You should wire it up as per the diagram.
gremlin1234 - 29/6/18 at 02:04 PM
yea,
looking at it again, the gauge appears to have its own voltage regulation, in that it can be used 12/24V
Dick Axtell - 1/7/18 at 02:58 PM
So - wired up gauge as per diagram above, and tested using PP3 batter, as suggested by gremln1234.
And it doesn't seem to work ! The gauge definitely makes a noise, but there is no needle deflection.
gremlin1234 - 1/7/18 at 03:06 PM
ok, try it on a car battery
David Jenkins - 1/7/18 at 05:09 PM
You'd be better off with one of these - they give a lot of power, are tiny in size and give off hardly any heat.
