help with connector name
number-1 - 24/10/18 at 05:01 PM
Can anyone tell me the correct name of this part? Ive searched for shell connector but cant find much info about it so presume its called something else?
N1
gaz_gaz - 24/10/18 at 05:10 PM
https://www.ebay.co.uk/itm/GX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-/372040618103?var=&ul_ref=http%3A%2F%2 Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Futm_source%3Dtwenga%26utm_param%3DeyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzEyMzZjOWExNTI5MTYzYTEyYW EwNTMxOWQzY2ZkMiIsImkiOiI1OTc2NzA4ODE2ODc2NDY1MTcxIiwidHMiOjE1NDA0MDA5MjYsInYiOjMsInNvIjoxNTAwLCJjIjoxODE4Nzd9%26utm_campaign%3Dtwenga%26utm_medium%3D cpc%26ff3%3D4%26pub%3D5574631662%26toolid%3D10001%26campid%3D5338353462%26customid%3D031236c9a1529163a12aa05319d3cfd2%26mpre%3Dhttp%253A%252F%252Fwww. ebay.co.uk%252Fitm%252FGX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-%252F372040618103%253Fvar%253D%26srcrot%3D710- 53481-19255-0%26rvr_id%3D1715768031509%26rvr_ts%3Da70cd4691660abc33073d164ffff55b4&ul_noapp=true&redirect=mobile
britishtrident - 24/10/18 at 05:12 PM
Aviation connector
gremlin1234 - 24/10/18 at 08:11 PM
looks very like the connector for CB (&ham) microphones
https://www.amazon.com/PIN-PANEL-MOUNT-MICROPHONE-CONNECTOR/dp/B00H579TXU
HowardB - 25/10/18 at 07:37 AM
typically called 4 pin Din, also available in anything from 2 to 13 pin,... not suitable for high current or high voltage,...
gremlin1234 - 25/10/18 at 09:29 AM
the one posted is not 4 pin din, they dont have the locking ring. also the din ones have smaller pins.
https://en.wikipedia.org/wiki/DIN_connector
nick205 - 25/10/18 at 09:42 AM
N1
Are you wanting to source one half of it so you can connect to an existing other half you already have?
If you can't find/identify it you might be as well to replace the complete connector with something you can source.
number-1 - 25/10/18 at 03:37 PM
Cheers for the replies lads
Its for push button gear changes. The buttons are on a steering wheel. Its going to connect to the cable so the steering wheel can be removed as needed
gremlin1234 - 25/10/18 at 08:51 PM
in that case its very likely you could/should also use the nice coily cable from the microphones that I referred to earlier.
coyoteboy - 26/10/18 at 12:29 AM
https://www.amazon.co.uk/Maplin-Audio-Locking-Connector-Socket/dp/B005XK8ZDQ
