Front Arch Help
Dan Regan - 3/9/15 at 10:06 AM
Hi guys, im new to the roadster so not really sure what i can do with the following.
Im having problems with the front arch brackets on both sides. both have snapped, i had the brackets welded back together but 1 day later they snapped again.
is there a permanent fix for this available anywhere?
regards
dan
Matt159888 - 3/9/15 at 03:44 PM
Hi mate I have a tiger and it too snaps the lugs all the time think solution is to rubber mount the wings it's the vibration that's kills them I think. Mind you the tiger is mounted with 2" 6mm bar it weighs a ton :-(
Dick Axtell - 3/9/15 at 04:13 PM
You should visit this site:-
http://www.lathyrus.eu/
It requires some lathe work, and isn't to everyone's taste. One day......
Dan Regan - 3/9/15 at 05:55 PM
It doeant seem to be the vibration thats doing, my guess is the wind and bumps whilst driving it. Ill try the mounts but i like the look of tying it to the outer side of the wheel as shown in that link.
steve m - 3/9/15 at 06:43 PM
What you need is some 25mm x 5mm steel bar,
that's what ive had on my car since 1998, never broken never given me any hassle, and have ever only had a couple of coats of black gloss on them
pics in my photo archive would help
steve
coozer - 3/9/15 at 07:27 PM
The bracket needs to be one piece, no welding as in a big U from the bottom mount with a lugs welded on.
That make sense?
steve m - 3/9/15 at 07:53 PM
mine isn't a big u, more of an H
Dan Regan - 6/9/15 at 03:13 PM
they look like they will do the job steve, fancy making me a set or know where i can purchase some?
mine currently look this this
[img]http://i.imgur.com/SFDCFZ1l.jpg?1[/img]
