Engine dipping
coyoteboy - 1/2/14 at 05:55 PM
Anyone know anywhere in Glasgow area that will hot dip my block and head before a rebuild?
v8kid - 1/2/14 at 06:53 PM
I'd also like to know if you find out!
In the past I've used hot caustic soda on three alloy v8 engines with no problems apart from the hassle of constructing a plastic dipping bath. I know doomongers will say it corrodes aluminium but that is not the case in my experience - remember it is important to soak in a weak acid ( that is a chemically weak acid not a diluted acid) eg vinegar afterwards.
However it causes one heck of a mess and there is all the sludge to get rid of afterwards i would be happy to pay £50 just to avoid the hastle.
I wonder if wood hot stripping companies would be OK after all its just caustic soda?
Cheers!
coyoteboy - 1/2/14 at 07:41 PM
Mines a cast iron block so less worried about the dip. The wood folk would probably dislike the oil? I thought about song it myself but my main prurpose would be to flush out my oil galleries etc and clean the outer for some painting.
doobrychat - 1/2/14 at 09:39 PM
when i did my van engine.. I had compressed air and got an old spray gun and filled it up with brake cleaner and blasted it everywhere.. made a mess but bought it up a treat before i rebuild it...
just an idea for you...
v8kid - 1/2/14 at 11:10 PM
Yup I remember now I used bottle cleaners to check the oil galleries with but they were clear. Disturbingly the last block a range rover one still had a load of casting sand in the waterways
coyoteboy - 2/2/14 at 04:15 PM
You mean sand isn't meant to be in the waterways?!
