Does anybody know this car?
Jasmcauley - 26/12/16 at 08:12 PM
My friend is thinking of going to look at the below, I've done a bit of searching and I can see that it was built by a college tutor, but not much else.
I don't know much about the chassis set up.
A brief spec
First of all, the chassis originally is a dutton chassis, bought complete with V5 and VIN plates attached to prove. Then the rear was converted to house a ford rear differential and independent double wish bones, (theys are fully adjustable). The front double wish bone suspension is wider then standard and completely adjustable (camber, caster & toe).
It has a c20xe 2.0 litre red top engine from a low mileage 1990 Astra gte.
Completely reconditioned engine, with new big & main bearing and piston rings.
The fuel is supplied by Yamaha R1 bike carbs & pipercross filter.
The ignition system is a ford DIS system married to a fully re-mappable mega jolt system. It has a USB plug, tucked under the passenger dash, to plug into a laptop for re-mapping.
Type 9 Box
The body panels are constructed from strengthened rolled aluminium riveted at 25mm intervals and bonded to the chassis
Any help or info greatly appreciated
slingshot2000 - 26/12/16 at 08:22 PM
Your friend should be VERY careful with car, as I cannot see a single part of it that could make me think it is a Dutton.
Ringer or not, it cannot have been correctly registered and will very likely not have been IVAed.
Jasmcauley - 26/12/16 at 08:33 PM
thanks for the heads up,
What do you mean it won't have been correctly IVAd?
Jasmcauley - 26/12/16 at 08:37 PM
Ignore me, I re read the post.
Correct me if I am wrong, It would appear it is living its life on Dutton v5
What kit would you say it is?
coozer - 26/12/16 at 08:37 PM
Just looks like whoever has bought a Dutton for peanuts and used the v5 on that car to avoid paying for iva/sva..
Its the totally wrong shape for a Dutton IMO, looks like a locost or an mk...
If you get a copper who knows what a Dutton looks like your in trouble and the insurance company will shake their heads as well...
CosKev3 - 26/12/16 at 08:40 PM
There was a thread a couple of months ago about this car
loggyboy - 26/12/16 at 08:41 PM
Not correctly IVAd is unintentionally misleading, not IVAd at all is most likely.
What's happend is some one has brought an aging Dutton cheap, then added the plates (and probably the VIN) to a new chassis/car that has never been checked or approved.
The main problems with that:
-Technically its a ringer (another cars ID swapped to another)
-its never been properly checked over by a official body (if it's been on road for a few years his is less of an issue as its likely to have had any teething problens ironed out.)
-insurance might get funny cone pay out time (although kitcars are niche enough to have little back up on what they should or shouldn't be called or designed)
-resales to those in know make it harder to sell on.
[Edited on 26-12-16 by loggyboy]
femster87 - 26/12/16 at 08:44 PM
Looks like a gbs zero bodywork
Jasmcauley - 26/12/16 at 08:51 PM
Looks like an early MK.
big thanks all, Jamie is gutted, but I think it's best that we avoid this one for so many reasons.
Looks a nice car, but it shouldn't be on the road
sdh2903 - 26/12/16 at 08:54 PM
Wise choice
perksy - 27/12/16 at 10:03 AM
As others have said, Its NOT a Dutton and is incorrectly registered
There will always be other cars, Just keep looking at the right one will come along
Gord - 28/12/16 at 05:42 PM
This is also on a FB page, the owner apparently bought it and had not realised the consequences of it being registered as the donor vehicle.
Apparently he is going to get it IVA'd properly now.
kingster996 - 28/12/16 at 10:59 PM
Sadly the owner was conned as the only "donor" component would have been the VIN number!
Amazes me that people are so gullible, but I guess some things look like a bargain and then only come to light when get lumbered with a problem when selling it on - especially after spending money on upgrades. Fortunately the OP was not so gullible and asked on here first!
Also amazes me that people go to the effort of building one only to ring it - surely the old SVA wasn't that expensive and even an IVA isn't that difficult (done that)
mark chandler - 29/12/16 at 03:28 AM
It was common practice 30 years ago to register against the donor, even if the only parts used were the triumph front uprights, these type of cars also morph as engines get swapped out etc. Look at older cobra replica's as an example.
Not saying it's right but no need to get in such a sweat about these things, if the price allows you to put through IVA and you are still on top what's the big issue?
Jasmcauley - 29/12/16 at 09:12 AM
Calm yourself, nobody is sweating.
The car shouldn't be on the road. And at the original asking price of 7500 I think it's fair that people know what they are buying. If they then want to take the gamble, that is their choice
SCAR - 29/12/16 at 10:04 AM
"Not saying it's right but no need to get in such a sweat about these things, if the price allows you to put through IVA and you are still on top what's the big issue?"
I think there is a big issue
Its running on the wrong identity so presumably has no valid paperwork, you have to question if its stolen? How would you prove you had bought it? Any receipt would say you've bought a Dutton (as shown on the v5) What would you declare it to be on any insurance? Would that insurance be valid?
If it gets picked up running with the Dutton plates legally it could be confiscated and crushed.
Can a car be put through Iva with no build information/receipts or donor v5?
The reason people get "in a sweat" is because potentially there is a major deception involved here which could result in some innocent party sustaining a huge financial loss and another kick to the reputation of kit built cars.
