Zeus on the Dyno
jeffw - 17/4/19 at 01:37 PM
https://youtu.be/iukdsIXgWAY
Fault finding a miss-fire
theduck - 17/4/19 at 03:32 PM
Sounding great, even if you are only fault finding!
jeffw - 17/4/19 at 03:43 PM
We'd fixed the fault by this point and where just checking the Calibration, this is a low boost run.
theduck - 17/4/19 at 03:47 PM
How much boost is low boost?
and go on, how much did it make?
jeffw - 17/4/19 at 04:14 PM
446.7 @ 9940rpm at the wheels. 1.5bar of boost
theduck - 17/4/19 at 04:22 PM
I love that your low boost is higher than my high boost, and I thought 20psi was a lot of boost!
jeffw - 17/4/19 at 04:23 PM
high boost is 2 bar....
Did you like the colour of the exhaust?
[Edited on 17/4/19 by jeffw]
theduck - 17/4/19 at 04:38 PM
I'd missed that first watch! Gotta love a glowing manifold
My motor should handle up to about 2.5 bar, but that would require bigger turbo, bigger injectors, stronger gearbox and changing the rear end to accept a ford 8.8 diff, and even after all that i'd probably want to move the whole lot into a more suitable chassis anyway, I'll be leaving it as it is for now. It is still going to be by far the fastest car I have ever owned, as even on "low boost" it was making more power than the fastest car I have ever owned and is about half the weight!
[Edited on 17/4/19 by theduck]
HowardB - 18/4/19 at 09:07 AM
that looks and sounds amazing!
well impressed -
jeffw - 18/4/19 at 12:12 PM
jeffw - 19/4/19 at 05:36 AM
Another viewpoint
https://youtu.be/9Esj0NwA_fs
